Question about Whirlpool WTW5600XW Cabrio Energy Star Top Load Washer - 11 Cycles - White
Cannot remove Cabrio basket from tub.
What could possibly hold basket after cap, agitator, hubs removed? Doesn't the shaft thread into bottom assembly? Should I remove bottom (motor, et al) then pound out drive shaft through top?
    Novelist:
  • 150 Answers
Once the spanner nut is removed, which is underneath the wash plate, the tub is designed to lift off the drive shaft, this is often not the case at the the metals often corrode, and fuse together causing non removal. In some cases damage to various parts has to occur in order to get things apart. Pleazer Appliance...
Posted on Apr 17, 2014
  • Steve Reiss
    Steve Reiss Apr 17, 2014
    Thanks for the quick reply, but what damage and how? Will some white vinegar alone, or in combination with salt sprayed on the shaft dissolve enough rust to possibly free the basket? Any dangers or other specific suggestions? I cannot find a video or tutorial of specific steps when this problem occurs- with a particular solution.
  • Steve Reiss
    Steve Reiss Apr 19, 2014
    I got it! The vinegar was the key. I sprayed it around the shaft, and the next day it finally came off. For those that have trouble, there is nothing besides rust/ sediment around the shaft that prevents you from lifting it off. I used an "impact wrench" method of short, quick tugs instead of longer pulls.
SOURCE: I want to remove the
@ bottom of basket there is to rubber plugs remove them then basket will come up without the drive bell
Posted on Oct 17, 2009
  • 20 Answers
SOURCE: my whirlpool cabrio top loading washer with corner
You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
Posted on Sep 29, 2010
lancaster5
  • 245 Answers
SOURCE: How to disassemble the agitator after removing
After you remove the cap on top there will be a 7/16 nut. Remove that nut. The whole thing should slide up and off. If you put the agitator on the ground and stand on two sides of the base and give a quick ****, It will seperate. Slide the sleeve away from the dogs and replace them. The top snaps back together, slde back on spindle and replace the 7/16 bolt. Replace cap.
Posted on Sep 06, 2010
TheMobilian
  • 8220 Answers
SOURCE: how do you remove agitator cap cabrio
Cabrio Service Manual
Posted on Jun 22, 2012
caroldon
  • 17129 Answers
SOURCE: how to remove hub from whirlpool cabrio wtw5600wxo
Please click on this link: Bearing removal
Posted on Jul 27, 2012
Can "ol" error because by spongy floor tiles or a move?
If you've already tried putting it on a piece of 3/4" plywood, try running it with a small load. If the error persists you could have dislodged one or more of the tub suspension springs so open the top (like the hood of a car) and check the 4 springs. If the unit is old and the springs are worn they can be replaced.
May 28, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
How to service tub & agitator
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
on Jan 16, 2010 | Washing Machines
My washer is blinking F 50. what do I do?
Motor has stalled, check under basket, for something around shaft,you will need to pull out basket ,pop the cap off the agitator, remove bolt ,unsnap tub ring remove return hose ,pull the basket out, clean area area shaft
Jan 27, 2011 | Whirlpool WTW6400SW Cabrio Washer
How do i remove the agitator to remove a tangled drawstring
To remove the agitator you need to unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator if you want and replace the agitator cap.
Note: Damage to the snubbed, a pad like device sometimes located under the agitator cap, can cause the machine to vibrate excessively. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
It knocks on spin cycle
The tub may be off balance.
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
Sep 10, 2009 | Washing Machines
Clothes get stuck between drum and opening, come out with "burn marks"
There should be a felt type seal on the drum in that opening to prevent this. It could be that it fell off or wore out. It is a hassle to put on unless you have good access but not difficult with a bit of patience.
Sep 04, 2009 | Kenmore 73952 Gas Dryer
Washer drum bangs from front to back
This may be a drum or agitator problem. Possibly bad bearings or coupler
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
The agitator stops moving during the wash period, and sometimes it slow when is suppose to be spinning to remove the water from the clothes.
We will conclude our tour of the washing machine on the next page with tips for servicing the water pump, the belts and pulleys, and the motor.
Servicing Water-Related Problems, Belts, Pulleys, and the Motor
On this page we will explore some of the more mechanical parts of a washing machine like belts, pulleys and the motor. First, we have some tips for water-related problems.
Aug 24, 2009 | Washing Machines
When in spin cycle the tub is loose and makes a banging noice.
if the basket has excess movement separate from the agitator or tub then the hub nut may be loose or maybe the tub rusted out and broke. you will need to pop the top of the agitator off and remove bolt holding it to shaft, pull agitator out and look at hub nut.
Apr 28, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool WTW5600XW Cabrio Energy Star Top Load Washer - 11 Cycles - White Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
