Question about Kenmore 63942 Dryer
Dryer will not turn on sometimes.
The dryer has started to not turn on when pushing the start button. There is a sound like the moter starts to run but quits and then nothing. After sitting a few minutes it will start but immediately sounds like motor grinding when first starts. Then the dryer has a different sound than before.
Need to fix this before it leaves my wife stranded and does not ever start at all.
Thanks
  • 126 Answers
Bad motor no doubt about it.Act quick
Posted on Jun 19, 2009
I think its the moter
Sounds like you have solved the problem but a part needs to be replaced in this dryer?
Nov 07, 2012 | Computers & Internet
The dryer does not spin when start button is pushed. It makes a noise and a burning smell. Like a burned moter.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 18, 2011 | Dryers
Dryer stopped running, wont turn on, i have power to motor, i hooked a meter to the two blue wires on moter and pushed the start button, power is there, but i assume the motor burned up, not 100% sure but...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 30, 2010 | Whirlpool LER5636P Electric Dryer
Crosley dryer Cdes563sq0 if i turn the timer on befor i push the start button the heat will start but the moter dose not start.even after the button is pushed.
It sounds like there is a problem with the motor/belt. If you can get the top up, mine you have to push in two clips between the lid and the body about two inches in from the right and left sides, you can look down into the machine to see if the belt is still on track or if the motor is turning. I had one dryer that the belt would come off the spring tensioned idler pulley. Best of luck
Mar 21, 2010 | Crosley CDE6000 Electric Dryer
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Roper dryer by maytag press star button here noise but does not start?
you will nead someone to help you to see if you have a bad moter.first open door,with your right hand push in on the door switch.hold the switch in ,have someone push the start switch in and at the same time with your left hand turn the dryer drum clock wise,if the dryer starts than you have a bad moter.the cost of the moter would be 1/3off the cost off a new unit.
Nov 20, 2009 | Roper REX4634KQ Electric Dryer
When start button is pressed, dryer just buzzes. Has worked 3 or 4 times, but its rarely and only occasional. With the fact that it has started it certainly can't be the motor. Have replaced the pig...
This could be your start switch has gone out. That is what it sounds like to me.
Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service for service information and parts.
We answer our customers calls from 7 AM until
9 PM CST so give us a call when you need us.
Thanks, Ella
Nov 11, 2009 | Whirlpool LER4634J Electric Dryer
Dryer has power when i hit the start button it hums and dryer does not spin or heat
you will nead a nother person to help you see if you have a bad moter.first you nead to open the door and with one hand you nead to push in and holddoor switch, now have someone push in on the start switch and at the same time you nead to take your other hand and turn the dryer drum clockwise,if dryer start's than you have a bad moter.
Nov 08, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 63942 Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
