Question about Toro Lawn Mower With Toro Power Tools
My blades on my toro timecutter zs 4200tf are not engaging
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
Toro timecutter rough idle, backfires, loses power when blades engaged. Spark plug is gapped correctly, have even changed spark plug with no change.
might check the valves to see if they are set correctly and push rods not bent. turn engine over by hand to be sure valves are opening and closing . or check the flywheel key. if it has sheared it will cause it to back fire as the timing will be off.
Jun 12, 2017 | Toro Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
I jave a toro timecutter z5035 and it starting making a popping noise when running. When blades are engaged the blades turn slow and the engine idles down and then will pick up running for for 30 sec
clean the spark plug or even change it , when you store it you must run it out of gas which means shut the gas off so the gas does not turn into polish that clogs you carb , needle and seat etc ,
Jan 17, 2015 | Toro Garden
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Toro timecutter42 blades squealing and won't turn
just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Toro timecutter spits and sputters when blades are engaged
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
37 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
