Question about ASUS Us Ve228 H 21.5 Inch Lcd Monitor
Ubuntu asus ve228 - ASUS Us Ve228 H 21.5 Inch Lcd Monitor
How do I remove ubuntu linux from Asus Eee 900 and replace with EasyPeasy?
Go to geteasypeasy.com. Download it install it and then in options remove Ubuntu.
Easypeasy is actually Ubuntu so I doubt you will notice more than a few things won't work anymore.
Jul 26, 2014 | ASUS Eee PC 900 Notebook
How to reboot my Asus Eee PC series Operating system: Linux (Ubuntu) Any ideas on how to fix it
What exactly do you mean by reboot?
If you mean by restarting OS In ubuntu, you can do it by clicking the power option found in TOP right corner right beside time.
Hope this helps.
Mar 14, 2011 | ASUS Eee PC 900 PC Notebook
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
Jul 07, 2010 | Canonical Ltd. Ubuntu
Install asus crw 5224a in ubuntu
I think that you have an internal unit not an external one like pictured.
Just hook it up like normal and try booting your system with an Ubuntu Live Cd in your drive. It should just work.
Ok... maybe you'll have to explore your BIOS to find how to let the system boot from a CD, but that's usually a bit of quick trial and error.
Good luck.
Mar 16, 2010 | ASUS CRW 5224A CD-RW Burner
I can instal skype in asus eee pc 900 vith ubuntu software
yup .. goto skype website and choose to download skype for ubuntu.
Feb 10, 2010 | ASUS Eee PC 900 PC Notebook
How do i use asus motherboard features in ubuntu linux .where do i get asus linux drivers for asus p5q motherboard?
Linux Ubuntu is fully automated. It is backward compatible with old hardware. You should have no problem installing and using it.
It will look for any drivers it needs. It has a vast repository of drivers and software. I have run it on a variety of machines and virtual machines with no problems.
Nov 10, 2009 | Computers & Internet
Which ubuntu version for ASUS P5M2
Its usually good to specify in as much detail the motherboard specs. First you need the Server edition of the latest or any (stable). Next your boar is not considered a server (ASUS P5M2 series like Asus P5M2-E/4L uses Intel Core 2 Duo chip technology which is officially(according to Intel) for Desktops and notebooks ONLY. However, it supports the 64bit architecture. So you can do the Ubuntu 9.10 Server or Ubuntu 8.04 Server 64bit.
Nov 05, 2009 | ASUS P5M2 Motherboard
ASUS Us Ve228 H 21.5 Inch Lcd Monitor Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
