Question about Samsung Gravity Touch T669
Reset samsung t669 - Samsung Gravity Touch T669
I forgot my password for my samsung t669
okayy first take out ur sim card for the phone then turn it on afterwards if it asks you for a password type in *2767*3855# but if the phone turns on go to the dialer button and type in *2767*3855# and then it will tell you to wait then take out the battery and put in your sim card and turn on the phone now your phone is reset !!! (;
Jan 17, 2012 | Samsung Gravity Touch T669
Hi I bought a Samsung t669 at a Flea Market and wanted to take it back to Germany with me. The phone is with AT&T and the sim is locked. Can you help me unlock the phone
Hi,here is the guide link below describing to unlock your phone...good luck.....
Hope this helps!
Take care and please
Remember to rate / vote us
to continue f
or Helping out the Community :)
Thanks
How to Unlock Samsung T669 Gravity T Posted on September 8, 2010, 12:04 am, by admin, under CellUnlocker How Tos. This is guide on how to unlock your Samsung T669 Gravity T to any GSM network.
Phones will often come locked to a certain carrier or network so you cannot switch simcards using the same phone.
http://www.cellunlocker.net/blog/2010/09/how-to-unlock-samsung-t669-gravity-t/
Aug 17, 2011 | Samsung Cell Phones
How do i unlock my Samsung Gravity Touch T669
Use the Unlock code to Unlock the samsung T669 Gravity T(Touch) using the Unlock it from Network LOCK,Specify the Network ,Country Locked and get the Unlock code from the site named as
Simpleunlocking.com and Unlock it...
Samsung T669 Gravity T Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung T669 Gravity T mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung T669 Gravity T mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung T669 Gravity T with a NOT ACCEPTED SIM Card.
2 - Samsung T669 Gravity T will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung T669 Gravity T shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung T669 Gravity T.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung T669 Gravity T is locked to.
CODE: Its the unique Unlock Code for your Samsung T669 Gravity T.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung T669 Gravity T.
Aug 08, 2011 | Samsung Gravity Touch T669
I need help to take a freeze off of a samsung gravity t 669.
You need to Unfreeze the Phone,You can get the Unfreeze Code from here Prounlocking.com and Unfreeze the Phone from Freeze ....
Login ' Register ' Currency Pro Unlocking.com Experts in Mobile Phone Unlocking rrmus-8.gif Samsung T669 Gravity T samsung-sgh-t669.gif Country Network Samsung T669 Gravity T Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung T669 Gravity T mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung T669 Gravity T mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
Method 2:
Aug 01, 2011 | Samsung SYNC SGH-A707 Cellular Phone
Paid thirty dollars for a unlock code so my t- mobile phone would work on at&t but it did know good
Are you sure your samsung gravity SGH t669 unlock code for t-mobile network? To unlock your network phone you must used samsung unlock code according to your original network sim card, but if you sure that the code is correct, try to reset your phone after unlocked process. See that' solve your problem or not? If can't solve your problem i doubt you have correct unlock code. Good luck!
Jul 16, 2011 | BargainCell GTMax 3pk LCD Screen Protector...
How to unlock samsung gravity T669
You can Unlock the Samsung Gravity T669 using the Unlock code ,you can get the Unlock code at
Superunlockcodes.com and Unlock it,Then follow the instructions below to Unlock it step by step,check code for Your Country's Network Lock.
Method 1:
Method 2:
Each Samsung T669 Gravity T mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung T669 Gravity T mobile phone using the form above.
May 22, 2011 | Cell Phones
How do you master reset a gravity touch
If your Samsung Gravity T (T669) is stuck on the PIN lock screen and you do not have the code to unlock, you can try a master unlock code... 73683139 to override and then go to settings and turn off lock feature. When you reactivate lock feature it will prompt you to select a new PIN.
If your phone requires the T-mobile PUK code to unlock (you get a message that says call support PIN is locked) the PUK unlock for this phone is **05*22998214*0000*0000#. This will unlock device and reset PIN to 0000.
Enjoy.
Jan 24, 2011 | Samsung Gravity Touch T669
Hot to unfreeze a samsung gravity t669?
i need to unfreeze a samsung t669
Nov 24, 2010 | Cell Phones
Samsung Gravity Touch T669 Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
