Question about Music
Chase upright piano serial number 64966
Upright piano
5 Suggested Answers
  • 5603 Answers
SOURCE: We have a Kimball Player upright,it has model C
Find the coil voltage and whether it is AC or DC coil andd the contact configuration. The search for relays at Digikey,com, Mouser.com, and others.
DO NOT replace the relays UNLESS you can see that the contacts are bad and fail to close. If the relay fails to move, verify the coil is open with an ohmmeter since a bad driver transistor will fail to actuate the relays.
OFTEN you can fix a sticky relay. You may find contamination in the magnet area that keeps it from closing. Remove a relay and actuate it observing operation looking for the problem.
SOME relays are used to protect speakers if the power amps don't balance... one can damage the speakers in this case. Manually actuating those relays will result in a pop in the speakers although sound MAY come out.
Posted on Jan 23, 2011
  • 31 Answers
SOURCE: how do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Posted on Feb 27, 2015
AndrexT
  • 20927 Answers
SOURCE: We bought this upright piano for our daughter to learn on but I can't seem to find any info on it. Serial number 23930. Any info would be fabulous. Thank you.
Remove the front of the piano. Remove the middle C key complete from it mounting pin. You may find the production date and its full service history written in pencil on the side of that key. A piano tuner told me this after I told him that I had removed all the keys to clean them and I was surprised to see the whole history. It said it was standard practice.
Here is some other information.
Concord Mission Style Upright Piano ' The Antique Piano ...
antiquepianoshop.com/product/192/concord-mission-style-upright-piano/ The Concord Piano Company was controlled and manufactured by the famous George P. Bent Piano Company of Chicago, and they built pianos for several ...
Concord ' The Antique Piano Shop
antiquepianoshop.com/online-museum/concord/ (SEE ALSO: CROWN, GEORGE P. BENT) The Concord Piano Company was ... and manufactured by the famous George P. Bent Piano Company of Chicago.
Upright Piano Value ' key-notes
www.key-notes.com/upright-piano-value.html Jun 16, 2014 - Question: I have a Concord upright cabinet grand piano, serial ... Albert's reply: Piano values are based on information such as manufacturer, ...
Piano Manufacturers in Illinois between 1842 and 1908
https://sweeneypiano.com/.../manufacturers/il_piano_manufacturers.cfm The names of Piano Manufacturers and the date year the company was established in the state of Illinois between 1789 and 1911. ... Company, Chicago. Foley & Williams Piano Manfacturing Company, Chicago ... Concord Company, Chicago.
Posted on Jan 19, 2016
  • 45018 Answers
SOURCE: how much is my 1910 Netzow Upright Cabnet Grand Piano worth
Fixya does not do appraisals.
Posted on Oct 28, 2016
The number stamped on the back of my piano is 57866 don't know the maker? any clue?
Jacob Brothers from 1921 according to the link shown:
https://www.mypianofriends.com/i-have-a-jacob-brothers-piano-model-number-57866-but-i-cant-find-any-infor...-107545.html
Quoting:
I have a Jacob Brothers piano model number 57866 but I can't find any infor... by Guest 5 days ago
9
I have a Jacob Brothers piano model number 57866 but I can't find any infor... I have a Jacob Brothers piano model number 57866 but I can't find any information on it? Anyone know anything regarding this model?
Posted on Questions & Answers
Answer
4 days ago C. Anthony
Guru
Blogs: 48
Forum: 16,526
Votes: 420 What type of information do you want? you have the piano in front of you!
specifically what do you want to know?
the SN shows 1921 date.
Have you tuned it this year? If the piano will not hold tune to A=440hz, the value would be 0. However, I would think it would hold 440...but I may not.
Call your local piano technician to check it fully.
CAPReply
This Might Interest You
Jacob Brothers I am trying to find the year my Jacob Brothers Player Piano serial number 6... I've got an Emerson piano. Serial number 114689. I can't find a price on it... Links For Piano Serial Number/Dates What is year of manufacture of Jacob Brothers piano serial #... How much is my Jacob Brothers upright piano worth? And what estimaTed year ... I have just come into the possession of a Jacob Brothers Baby Grand piano S... Finding the serial number of your piano Where do I find the model and serial number of a young chang baby grand pia... Jacob brothers? Jacob Brothers Piano Jacob Brothers Piano I have Baldwin serial number 305931 how do I find te model number and when ... What is date of manufacture of Jacob Brothers piano serial #43470? Thanks! What would be the age of Jacob brothers upright piano serial number 28259? How do I find serial number and date of jacobs brothers upright piano? When was/by whom/ and where was my jacob brothers piano made and what is it... Where can I find piano's make and model?
Apr 28, 2018 | The Music
I have a piano made by Laffargue piano co ewyork. The serial number is 70805. The piano has Seaverns written on it. Can you tell me the age of my piano please?
(1905)!! Please Read On How To Tell How Old Your Piano Is !! I Learned This From Grandma !!
Piano serial numbers usually have five to seven digits, but may have fewer or more, depending on the manufacturer and age of your piano. Serial numbers may also include a letter as well.
Here are the TOP FIVE places to locate the serial number of your spinet, console, or upright piano:
Serial number locations are found:
1) On the piano's cast iron plate. After lifting up the lid, look along the top front area of the plate. The serial number may be to the right or the left, or in the middle.
2) Under the opened lid on the ledge, stamped on a little plaque, to the right or to the left.
3) Stamped on the back of the piano; near the top of the wood frame.
4) Printed on one of the hammers, found on either end of the piano (newer or imported pianos).
5) Printed on one the keys - behind the nameboard, inside the piano (newer or imported pianos)
Aug 25, 2017 | The Music
I have and antique Kimball serial number is 197287 trying to find out the value of it
Kimball piano values vary based on age and condition; as of 2015, many uprights sell for $10,000 or more. Kimball is a well-known brand, and several of its antique pianos are considered highly collectible.
The Kimball Piano Company, based in Chicago, was one of the largest piano manufacturers in the world. At the turn of the century, Kimball built approximately 20,000 pianos annually. Kimball produced pianos under different brand names such as Hinze, Dunbar, Whitney and Harrison. Styles were influenced by Victorian, Greek Revival and Arts and Crafts architecture, and upright models were often available as player pianos. Kimball was sold to the Jasper American Corporation in 1959, and its pianos were discontinued in 1996.
Apr 08, 2017 | The Music
Yamaha upright piano U1, serial number G1267822. Can you please tell me the age of the instrument, roughly? Thanks
With the given serial number I was able to determine that this piano was likely made between 1960-61.
Try this website for future reference: http://usa.yamaha.com/support/finding_age_of_yamaha_piano/
The serial number you gave falls between 124000 (1960) and 149000 (1961) which led me to my answer.
Hope this helps!
Aug 16, 2016 | Yamaha Music
Chas f. Netzow upright piano Serial number 47686
I should write this out to save me keep typing it. Remove the front of the piano and the lid for the keyboard. Remove the middle C key completely. You may find the manufacture date and its full service history written in pencil on the side of the key.
Netzow Piano Co. Brand Name: Netzow Piano Co. Parent company: Netzow Piano Co. Location: Milwaukee, Wisconsin Serial Numbers Available: yes First date listed: 1904 Last date listed: 1931 Other brands:
Answer
Hi Robyn:
serial 10305
This was one of the original pianos made by this company in 1904. The serial number is the determining factor in telling a piano's age.
The worth rests on the piano's viability, configuration, and age.
Old uprights are generally worth little, especially if they are not serviceable. The furniture value is secondary.
If your piano is in perfect condition, inside and out, the value would top out around 200.00, USD.
What you have there is a typical upright piano, which more than likely has more furniture value than instrument value.
Age is not good in the piano world and pianos deteriorate year by year whether they are played or not.
Are you using this piece as furniture, or instrument?
9k= 3 yearsy ago #3 jim H. Guest I have a Netzow upright #41459. What is the manufacture date?
Made in 1913.
Netzow Piano Serial 13072 What is its manufacture dat
Feb 07, 2016 | Music
Jan 19, 2016 | Music
How much is my old upright gulbransen piano worth and how old is it.serial number 213957
That serial number is from 1925. The piano's value would depend on it's condition and your local market.
Jan 28, 2015 | Music
Upright piano serial number
Here is a good place to look for your piano by make & serial number.
There are times when your piano name or number is not listed. They can help you find the year your piano was manufactured in most cases. Since you have the name & serial they should be able to answer your question.
http://www.bluebookofpianos.com/serial1.htm
Best of Luck
Apr 17, 2014 | Music
Piano value by serial number
If your piano was made for the U.S. and is a grand or upright, this serial number would show that this piano came from the mid 70's 1973-77 and was manufactured in Hamamatsu, Japan. You should be able to google your piano from here to find others similar to it to get a price or call your local piano tuner!
Apr 07, 2014 | Yamaha Music
Music Logo
19 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
