Question about Maytag Dishwashers
Dishwasher controls do not correctly respond to input
577-1
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
What does error code 577 on a 2003 Lincoln LS mean?
P0577 - Cruise Control Input High Priority
Jul 23, 2011 | 2003 Lincoln LS
Tried to run dishwasher but it wouldn't turn on -
If you have no power and no lights at all,you may have blown the fuse. There is a non-resettable fuse in the top right corner of the control board.Remove the 6 screws across the top of the console panel to access the board and fuse.
You can check the fuse for continuity with a meter set for ohms or continuity. Al;so check the door switch below the open/close lever for continuity.Check incoming power under the dishwasher were the incoming power wires connect.
Dec 26, 2009 | KitchenAid Dishwashers
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Power/standby light on no picture or sound
had same problem engineer seen and dignosed ysus board and buffer boards £577 to repair £
Dec 05, 2007 | LG 50PX4DR 50 in. Plasma TV
Dishwashers Logo
21 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
