Question about Mitel Lands Phones
Unlock superset 4025
The second and the third keys on each side re lite up in red. There is no dial tone and can not call out. What happened?
    Novelist:
    Scholar:
  • 114 Answers
Try rebooting the phone (unplug & reconnect the phone line) If no improvement then try replacing the phone (swap it with another) - if still no joy then contact your PBX system maintainer. Hope this helps
Posted on Feb 23, 2015
leftypicker
  • 4 Answers
SOURCE: Changing time on my Mitel Superset 4025
The only way to change the time on your individual phone is to change the time on the entire phone system.
Posted on Mar 10, 2008
SOURCE: Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Posted on Jan 06, 2009
SOURCE: Mitel Superset 4025
Call forwarding is off. Voicemail not working on all 4 phones. You can transfer someone to the phone, and they can leave a message, but we cannot get the message.
Posted on Feb 25, 2009
  • 15 Answers
SOURCE: Checking Voicemail Remotely.
You will need to call in to the Voice Mail hub extension directly, then press * to identify yourself as a user (on some systems you may need to press # or press * twice). The system will ask for your extension and password and you will be granted access. Your system administrator can inform you of which extension is the VM hub on your system.
This is what Christ at Mitel told me. I'm still trying to find out our hub extension number.
Posted on Mar 05, 2009
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
Get display screen & soft key screen to light up on mitel 2000-superset 4025
Some 4025 supersets have back lit displays and some don't you may have the model that does not light.
Oct 07, 2014 | Mitel Lands Phones
Superset 4025 call pick up does not work
Call Pick-Up is a function that has to be programmed on the system controller. First a call pickup group has to be established, then extensions added to the group. Also a call pickup function key-combination needs to be defined in the System Options Assignment form. Contact your service company/PBX system support person for assistance with this. Hope this helps.
Jan 29, 2014 | Mitel Superset 4025 Corded Phone...
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
Plantronics headset connected to Mitel 4025 - won't work!!!!
You need to have a headset button on the set, and you need a release button if you want to transfer calls to others.
Press the Blue SuperKey and press all the buttons (one at a time) to find a spare button or find one that you do not use or need. Press the * button to change the button (scroll thru the options to find headset).
Once you made the button in to a headset button, press button to turn on or off the headset. Once the button is lit up, this means that the headset is active, now try pressing the call with the receiver off hook.
This should do the trick... if not write back and I will attempt to help you more.
Good Luck!
Mar 09, 2009 | Mitel Superset 4025 Corded Phone...
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Mitel superset 4025 - setting up a number to forward phone to
It is probably a system speed dial number. What mitel system do you have?
Nov 24, 2008 | Mitel Superset 4025 Corded Phone...
I have a 4025 Not Forwarding to VM?
The Call Forward is set up by using the BLUE Super KEY located below the display. You have to know the Voicemail Pilot Number to be able to complete the programming. Basically you press " superkey ", say NO to the prompts until Call Forwarding comes up, say YES to Call Fordward, choise the type of forward you want ( always, no answer, busy, busy/no answer )dial in the voicemail pilot number, press save and then press the superkey to exit programming. Good Luck
Aug 01, 2008 | Mitel Superset 4025 Corded Phone...
Mitel Superset 420 and 4025 -- RED --- WHY are these RED ??? Does anyone still buy these ??? plase also email me at shawnsmithnj@yahoo.com
Red phones were generally used as hot lines that automatically dialed a number; however, I have heard of some companies standardizing on red phones.
Feb 01, 2008 | Mitel Superset 4025 Corded Phone...
Lands Phones Logo
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
