Question about Fisher and Paykel E522BRXU Fisher & Paykel 17.1 cu. ft. Stainless Ice & Water Right Hinge Refrigerator
Fit fisher and paykel ice maker thermostat - Fisher and Paykel E522BRXU Fisher & Paykel 17.1 cu. ft. Stainless Ice & Water Right Hinge Refrigerator
  • 26 Answers
SOURCE: Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Posted on Mar 10, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge is less than
Try the video on the F&&P icemaker it will walk you thru diagnosing the problem. www.appliancehelponline.com/servicemanual.html
dj_relly999
  • 4070 Answers
SOURCE: I have a Fisher & Paykel Refrigerator. The
Hi! The refrigerator has dual valve with two coils at the back and the ice side may have gone bad thats why it doesnt make ice. YOu will have to have it replaced to get your fridge back to its normal working condition. Hope this helps and have a good one!
Posted on Aug 03, 2010
The sensor in the freezer has come loose
It belongs under the Ice tray to the Ice maker. Without it the unit can not detect temperature of the ice tray to cycle or function as needed.
I hope this helps.
Mar 23, 2013 | Fisher Paykel E522BRXFDU Fisher & Paykel...
My 3mth old e522brxu fisher and paykel ice maker has stopped working water is working fine you can manually force a dump and hear the cycle start to turn the tray but no water fills the tray can not hear a...
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
May 26, 2011 | Fisher and Paykel E522BRXU Fisher & Paykel...
I have a Fisher & Paykel Refrigerator. The ice cube maker has stopped working and the 'force cycle' does not make the ice cube tray 'flip'. Any ideas?
Aug 03, 2010 | Fisher and Paykel Refrigerators
Fridge ice machine does not work, Model E522B, have turned machine off and then back on, cleaned ice machine and replaced it in proper place,
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Hope this helpout.....
Jul 28, 2010 | Fisher and Paykel Active Smart E522B...
I cleaned out ice bin and now ice will not make on fisher paykel
did you turn the oce maker back on also check that when you pulled the bin out you did not pull the powr plug out of the side of the freezer just enough it don't work
Apr 22, 2010 | Refrigerators
Ice maker not working. Fridge keeps beeping when opened
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hlk;;lhk
Jan 31, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Model E522B - Ice Maker not working - forced cycle does not flip tray. Water dispenser is working ok. Freeze r temperature set low.
freeze tempt even tho set low / how low is it / must be 0 to 5 deg too work well . it stops at 15 deg .. . make sure both fans are working and the cond coil is clean . .. very important . .. water disp does not work with ice maker . you have a dual valve in the back with two coils . the ice side may have gone bad . if so replace the valve . both sides / only way it comes . hope this helps **** ..
Jan 06, 2010 | Fisher and Paykel E522BRXU Fisher & Paykel...
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Fisher and Paykel E522BRXU Fisher & Paykel 17.1 cu. ft. Stainless Ice & Water Right Hinge Refrigerator Logo
13 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
