Question about GE Spectra JGBP35 Gas Kitchen Range
Oven temp off by about 100 degrees - GE Spectra JGBP35 Gas Kitchen Range
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Oven only heats up to 100 degrees, but the temp on
Right now, it's a toss-up. The only way to separate the two possibilities is to first find the nominal value of the sensor, then measure it.
Posted on Feb 26, 2009
GodBlessU
  • 3513 Answers
SOURCE: oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Posted on Sep 09, 2009
SOURCE: When I set the oven, the temp displays 100 degrees
THE OVEN KEEPS ALARMING NOISE WITH A F7 NOTICE AND NOW WILL NOT HEAT WELL?
Posted on Oct 31, 2009
  • 61 Answers
SOURCE: ge built in gas oven jgrp17
ignitor? if you need a part check out www.appliancepartssolutions.com
Posted on Jan 21, 2010
GE-XL44 - OVEN DOES NOT HEAT ABOVE 100 DEGREES
Check the temperature probe. It should read 1100 Ohms at room temp.
Post back the results.
Dec 08, 2012 | Kitchen Ranges
What's an f1 and f2 code mean???
The F1 code means that a button on the touchpad is stuck
The F2 means that the oven tempature was at least 100 degrees over what the temp it was set to was
the F1 will come sometimes if the ribbon connection on the touchpad doesnt fit well into the control board and other times it comes because the touchpad is defective
the F2 comes up because the control has measures the temp and thinks that when it set as lets say fro instiance 350 degrees the control thinks the temp ahs reached 450 degrees(100 plus over) typically the thing wrong when the F2 comes up is the oven sensor at room temp to be between 1060-1100 ohms
However if you are getting both error codes at the same time the only thing common to both is the oven control and if both at the same time i suspect the control is the problem
GENE
Sep 06, 2011 | Whirlpool Kitchen Ranges
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
How do you know when the oven achieves the desired temp? does the oven temp light go off?
Yes, but oven temperatures are notorious for being off. The best way to know what your internal temp is is to buy a half way decent oven thermometer and compare that reading with the oven temp setting. It is not uncommon to have a 50-100 degree difference.
Nov 26, 2009 | Kitchen Ranges
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
GE Spectra JGBP35 Gas Kitchen Range Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
