Question about KitchenAid Dishwashers
Dishwasher will not go into normal clean mode
Ken more 577-1
3 Suggested Answers
  • 864 Answers
SOURCE: We have a dishwasher that flashes clean light on
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Posted on Jul 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite dishwasher 577-9 17262402.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Where do I get a filter (Canada)
You should be able to find one on eBay I have a dishwasher and there is just a screen to clean out eBayeBay hope this helps Happy New Year
Dec 30, 2017 | Filter Vacuums
Trouble-shooting non-starting
When you perform the key dance of normal heat dry normal heat dry, that is DIAGNOSTIC MODE. The heavy black material is called "mastic" and has come loose from inside the door panel--the door panel must be replaced. I've seen the mastic come loose from heat and fall out of the bottom of the door. It acts like an insulator for sound and heat. It helps keep wires in position, etc. The dishwasher stopping could be from a clogged filter in the main pump, or a clogged drain motor. If the drain action is too slow, the computer will time out and stop. If the main pump is strangled for enough water due to a blocked filter, it will shut down to protect itself.
Aug 17, 2015 | Maytag Dishwashers
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
Can remove bottom of dishwasher to clean kenmore 577-0
I'm a little confused about your question and dishwasher model number.... Is this an older (more than 10 years old) dishwasher? Maybe could you send a picture? Well, I THINK I know what you're talking about, and you should be able to unscrew that "knob", but you may need to get or use one of those rubber pads used to remove tough jar lids.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 24, 2012 | Kenmore Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
I have a kenmore elite dishwasher 577-9 17262402. The clean light is flashing. How do I stop it from flashing to start the dishwasher?
May 21, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
