Question about Freezers
Westinghouse Freezer Model FJ303QL9 won't defrost
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Remove the back panel inside the freezer, the thermostat is clipped on the line going to the coil, you will have to check it with a multi meter with the meter set on olms it should read close to 0 when it is 32 degrees or lower, if not it needs replaced. you can remove it and use a glass of ice water to check it. the heating element is under the coil and if the meter is attached to both ends should read 0 if it is good if it does not have any reading when attached it needs replaced. if both test good you will need to replace the main control board. hope this helps
Posted on Apr 17, 2014
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
Where can I download a service manual for my Westinghouse Upright Freezer Model FJ303 as I think there is something wrong with the defrost system
Go to Westinghouse web site and see if they are available there. If not , call them and have themsend one. Your defrost system is should be defrosting 2-3times a day. Is it not defrosting at all or is there an ice buildup.
Mar 02, 2013 | Freezers
Fan on freezer won't com on but freezes food on
Hi and welcome to FixYa, I am Kelly.
There are 12 midelos that fall under the model number you passed. I will cite EV171NYMQ05 as a reference model number via this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769
The freezer fan should be on anytime the compressor is on. If there is an ice block built up on the evaporator coils it can lock the fan blade in place via the ice build up. Additionally... if the fan motor bearings are dry or coated with sludge this too can prevent the fan motor from operating. The fan motor is item 3 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28174432#d28174432
Detail views:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-motor-evap-item-number-ap4539455.aspx
To check the can motor all that is required is a simple continuity check across the 2 connector wires. You should read under 480 ohms.
If you discover that the fan blades are encased in ice... do a manual defrost: (be ready to tend to a water mess)
1. By first unplugging the unit and then removing the freezer contents.
2. Direct an external fan into the freezer compartment for just over 2 hours.
3. Make sure the compartement drain funnel is clear of obstructions. Item 11 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28158051#d28158051
After the 2 hour manual defrost period plug in the unit and test to see if the fan motor is running.
If it is running you may have an automatic defrost problem causing the ice build up. On a freezer the ice build up will start again if there is an automatic defrost problem in 3 - 5 days. Until the automatic defrost problem is corrected you will end up doing the manual defrost routine described above everytime you have improper cooling problems.
Components that can cause the automatic defrosting problems are
1. The defrost timer item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28257341#d28257341 Because it is not cycling or stuck in one position.
2. The defrost bi-metal thermostat item 9 above link (stuck closed)
3. The defrost heating element item 5 above link. (open)
And of course internal wiring....
Check the fan motor for continuity... if you attempt to lubricate it which is very difficult on this fan motor make sure you use paraffin based "Turbine oil" and not a regular household or automotive oil. Using any other oil will cause the fan to stop working in as little as 30 days.
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
WestingHouse frost free freezer alarm light is on freezer not working.
have your thermal defrost elements checked
please let me know if you need further assistance
Jan 18, 2011 | Freezers
Changed thermostat worked 4/5 days and defrosts again
take back of freezer out does the coil have a full frost pattern? make sure the bulb to the t stat is where it needs to be and make sure they didnt give you the wrong one it might be a frig stat
May 26, 2010 | Freezers
Have a Westinghouse 'Silhouette' Frost Free 415
The reason your "freezing up in the freezer" is your unit is not automatically defrosting. That part you describe is your defrost control, or at least A defrost control. You said while cleaning the back, safe to assume you meant the outside back of the cabinet? Look for a square plug, either black or white, with the same 3-1plug as the defrost control. But, I doubt that is your current defrost control, maybe the original, but the unit cannot run without the defrost control plugged in. Now, your current defrost control maybe defunct, or your defrost heater element, or bi metal thermostat, the latter two are located in the freezer, one at the top, the other at the bottom of the evaporator coil. Test the continuity through both of these parts, the bi metal t stat at top of evaporator needs to be tested while it is cold. Disconnect one end of the heater element to test its continuity. If both of these test ok, replace your defrost control.
Mar 29, 2010 | Freezers
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
Freezers Logo
97 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
