Question about Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher
Trying to turn on the optidry option on my new bosch dishwasher
I have a model #SHE43 and can not seem to get this turned on. the display codes that i see differ from what the manual says i should see when trying to activate the optidry...Thanks
5 Suggested Answers
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
57 varieties
  • 1653 Answers
SOURCE: I am looking for the operation manual for my
You can download it from the following Bosch Support Link
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ngfv1dacdcso0mchdb---alz&UMOBID=ngfv1ekcdcso0mchdb---alz
Posted on Oct 09, 2009
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Posted on Mar 06, 2010
SOURCE: How can I turn on
This model does not have a signal. The manual refers to one of the other models.
Posted on Jul 21, 2011
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
How do i operate a basic bosch dishwasher
On many Bosch dishwshers (especially those with the controls on top), they expect your to press the appropriate cycle and option(s) buttons, and then press the Start key, ALL WITH THE DOOR OPEN. Immediately after pressing the START button, close the door (within 3 seconds), and the dishwasher should start.
On other Bosch dishwashers, if you open the door, the poser button is automatically turned off. On those models, you must close the door, turn the Power button ON, and THEN press the appropriate cycle & options buttons. If your dishwasher has a START button, then press it; otherwise just wait 10 second with the door closed.
See? There is no such thing as a "basic bosch dishwasher". Next time, if you have a question, please provide the model number of your dishwasher (or other appliance).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 20, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Error code C1 PO......
Hello. Your model dishwasher has a recall on it. There is a potential problem with the control board. Call Bosch at (800)856-9226 to find out if your unit needs to have a new control board installed and re-programmed. This only covers the replacement of the control board--any other problem will be covered by the customer. You will need the model and serial number. Next, regarding your model's problem...this was gotten from another tech site(I'm a member of quite a few, lol)
"Sounds like the unit is stuck in the control coding mode. C1 is the proper coding for your model so you just need to lock it in.
To enter coding mode, press and hold the second, third, fourth and fifth buttons to the right of the display simultaneously, then turn the dishwasher on using the On/Off switch. The associated leds will be blinking to confirm coding mode.
Release all buttons to view control coding. To change coding, press the second button to scroll through codes C0 - C9. C1 is the correct code for your unit.
Turn the dishwasher off to save control coding and exit coding mode." I hope this helps you! Let me know if you need further assistance!---Thanks!
Jan 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Dishwasher SHU53152
Common problem, bad timer. Press Scrub Wash and Del/Econo at the same time and the cycle will end.
Apr 14, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher Logo
952 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
