Question about Sharp 13K-M100 13" TV
How to adjust picture resolution in LG CRT tv
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Jan 03, 2014 | LG Televison & Video
How do i increase the screen resolutions for the lg we-32Q10IP
I am fairly sure in VGA it is a fixed resolution---give LG a call with the model number and see how smart their customer service people are.
May 24, 2012 | LG Televison & Video
How can i improve my tv LG LH20 42" in terms of
There are a couple of things that you can try to see if the image clears up, or is to your liking. You can adjust the resolution of the picture via the menu in the tv. You can also try resetting the tv to the factory settings, via the menu. You can also try auto configuration, which is also a menu item. If you are using a dvd/blu-ray player, use the HDMI cable for optimum picture quality.
Mar 08, 2011 | LG 42LC2D 42 in. LCD HDTV
On my Apex TV screen, some of the picture is cut out. How can i adjust the TV resolution?
You cannot adjust the resolution in CRT TVs. Its not like a monitor that is compatible with a number of resolutions from a computer for example. CRT TVs resolution's dont work like that.They take an input usually from a composite, Svideo or coaxial source and display it on the screen.
When you say the picture is cut out is there a black bar on top/bottom/middle of the screen? In older CRT TVs that usually means a problem with the TV itself and would need to be taken in for repairs or replaced.
Mar 05, 2011 | Apex Digital AT2708S 27" TV
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
Cannot see the top of screen on my 32 inch Samsui tv?
for some reason your television is setting itself to an improper resolution the most common fix for this is to go into your screen setting your looking for picture format or resolution menu after finding that scroll through the options to find which suites you best after attempting this if the picture is still chopped off you will need to find your screen calibration and adjust those as nescecary
Apr 22, 2010 | Sansui 32" TV
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Picture problem
I adjusted the screen resolution on the computer
Jan 07, 2010 | LG 42LG50 42 in. LCD HDTV
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Sharp 13K-M100 13" TV Logo
12 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
