Question about Philips 50P8341 50" Rear Projection Television
Phillips 64" PTV Issues
It had two blown fuses and a cut power cord when I salvaged it, I soldered on a new power cord, replaced the fuses and the tv ran great for about 8 hours, then shut it's self off. It turned back on and shut it's self off immediately. We took a look at the fuses and they were fine, let it sit for an hour and it worked for another few hours before turning off. Every time it's turned on it turns it's self off sooner, no matter how long it's been turned off or unplugged. It was unplugged over night, ran for 40 minutes and turned its self off, there is no noise or light associated with it's being turned off, but when it comes back on there is an upside down rainbow on the top of the screen. Any help is greatly appretiated.
  • AJDS Nov 04, 2007
    I don't see any bad solders, I did find another blown fuse, I replaced it and the problem has not changed.
  • AJDS Nov 04, 2007
    I have been searching around the Phillips website and have discovered that the TV is a CRT Projection TV and model number 64P9161099 or 64P9161
  • 1,694 Answers
1) Not vertical problem
2) "upside down rainbow" at any time is a convergence issue
3) Replace STK convergence amp IC's
Let me know if you need more help...................T.
Posted on Nov 16, 2007
  • 143 Answers
Sounds like vertical problems see if you have bad solder connections then get back to me
Posted on Nov 02, 2007
No power phillips hdtv projection
Follow cord inside and as seen from rear to the right where cord enters there are at least one and maybe two fuses.
See if the fuses are good or bad.
Dec 13, 2012 | Philips 60PP9202 60" Rear Projection...
No power
First Check the power cord to TV, try a different one.
If you are experienced you can take the back panel off the TV
Check for
- Internal fuse inside TV might have blown, its on the power supply board (white fuse, slow blow)
- Buldging Capacitors or they may have leaked brown substance on top or circuit board
If you are going to do this yourself make sure you do not touch the contacts on under side of the circuit board that connect to the LARGE capacitor (looks like a giant battery)
Replacing the fuse is easy no experience needed, make sure you replace it for an exact match, it will say the rating on the metal caps at each end of the fuse.
If it is not the fuse you can de solder the blown capacitors and replace them with new ones.
Total Cost of repair if you have soldering iron and tools will only be about £3 or $5
Otherwise get a pro to repair it for you, but you might pay around £80 or $120
You can note down the model name on the power supply circuit board and Google it.
You might be able to buy a replacement power supply which will be cheaper than paying a TV repair man to get the part and fit it
Hope this helps
Apr 07, 2011 | Sharp Televison & Video
I have a Samsung LCD TV and it won't turn on
Hello! Just check your main power supply socket. If it is ok than just open your tv back cover and check the fuse. I am sure the fuse is burnt. If the fuse is also ok than you need to consult a technition. But mostly it is the problem of burning fuse
Apr 04, 2011 | Televison & Video
My Phillips had actually locked-up and have not been able to get it turn ON - tried switching batteries in the remote, tried disconnecting every cable, unplugging the unit, hitting the power switch on the...
hi....hope this can help...
try to check the power cord, see if there's a cut or open wire...
there's a possibility a open or no continuity of wires from plug to the power supply due to frequent bending of wires.. so no AC voltage goes through the wire..
second check for an internal fuse..if it has a open wire (hair like) inside it is visible inside the glass tube...if it is open or has light discoloration..replace fuse w/ same type/ value...if it is extreme dark discoloration you may have a shorted bridge type rectifier or power MOSFET...i suggest that if you have replace the fuse and tested the unit and still blown the not attempt to replace fuse and test the may cause further damage to the TV..ask assistance for repairing the power supply, it is repairable than to purchase a new power supply and gonna cost you less...good day... please rate and vote...
Feb 20, 2011 | Philips 42PFL5332D 42 in. LCD Television
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like, to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
I have a TV 48" PTV W/RemoteModel 6P4830W TV repair said that it
The problem is not in the bulb but in the display coolant... step by step procedures and illustrations are included in the kit.
Sep 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
Olevia 32in" no power at all
After taking the screws out and removing the back, you will see a power supply(where master switch and cord connector are). Remove the 4 screws on the aluminum cover plate to gain access to the fuse. Using a voltmeter, with the power on and switch on, measure the voltage on each side of the round fuse located just behind the cord connector. If voltage is 0, fuse is good. If voltage between 115 and 125 V, replace fuse or have fuse replaced. I think it is a 6.3Ah 250V class fuse that is soldered into the board. IF YOU ARE NOT FAMILIAR WITH SOLDERING TECHNIQUES AND PRECAUTIONS, DO NOT ATTEMPT TO DO THIS. IF YOU ARE NOT FULLY AWARE OF ALL SAFETY PRECAUTIONS NECESSARY TO MAKE THIS REPAIR HAVE A QUALIFIED TECHNICIAN DO IT FOR YOU!!!!!!
If a new power supply is needed, contact me and I can point you in the right direction.
Mar 22, 2009 | Olevia LT42HVi 42 in. LCD Television
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
No power for Sony ICFCD855V Dream Machine.
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
May 10, 2008 | Toshiba Sony ICFCD855V Clock Radio
Philips 50P8341 50" Rear Projection Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
