Question about Staples Micro-Cut Shredders; 16 Sheet
Jam Light will not go off - Staples Micro-Cut Shredders; 16 Sheet
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Paper jam light is continually on and I can't reset.
Did you check for jam in the back (open rear door maybe jam is there)?
Mar 26, 2009 | Lexmark E232 Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Staples Micro-Cut Shredders; 16 Sheet Logo
23 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Terry Hair
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
