Question about HP Pavilion a1410n (ER890AA) PC Desktop
System fan has failed
Hi to anyone who can tell me how to fix this problem.... an running out of patience with this message.....'' system fan has failed press f 2 to continue... my pc is a ptgd-la hp with windows xp sp 3 .. after restarting i get this message and sometimes i forget ... please any assistance will be granted
  • jtechnology Jun 18, 2009
    i tried all of these things and still the message pops..any more ideas
    Problem Solver:
  • 11 Answers
Try to load into bios (some cases depending on a model you can try with F1, F2 or F10 or even a DEL button on keyboard)..
Load bios F5 then save the changes F10 and try restarting the pc.. most of the cases it worked.
Posted on Jun 20, 2009
    Scholar:
  • 74 Answers
When the system fan or cpu fan fails you will get this message, or sometimes the computer will actually start, but then shut itself down. The only way to fix this problem is to replace the failed or failing fan. If you don't know how to replace a fan inside a computer, then I highly reccomend that you hire someone to replace it, or get a friend who knows what they are doing, to replace it.
Posted on Jun 18, 2009
    Scholar:
  • 124 Answers
Your system's fan has failed. If it is under warranty, you need to have HP made aware of this failure.
  • Traci in Texas Jul 03, 2009
    HP replaced the fan and it still is giving you the error?
    They need to re-fix it then.
    Call them back and make sure they understand that it is still giving you the problem!
    Problem Solver:
  • 6 Answers
You can check yur fan cables or yur fan might need 2 b replaced
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
Hp pavillion dv6000 I need to do a system recovery. How ?
  • Hi, these are instruction to perform the System Restore; follow them carefully! You will need Disks (CD or DVD); only if you needed to Backup System Files, before restoring the system; in which you may be (prompt) to do so. So have available beforehand, at least 7ea, of (DVD-R), or (DVD+R), or (DVD+RW) @ 4.7 GB ready! *Note: It is important to make, Recovery Disks for the computer as well, in the event of system failure! *System Restore: 1. Go, to: Control Panel 2. Click, on: System and Maintenance 3. Click, on: Backup and Restore Center 4. In the (left) Tasks area, click on Repair Windows using System Restore 5. Windows may take up to 5Mins, to Setup a Restore Point; be patience! 6. The restore Wizard 7. Use (Recommended) Restore Point. Be patience! your computer will Shutdown, and Restart. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running! *Conclusion: "Message successfully restored, or failed to complete restore? Follow “prompt message,” for further recommendations." "Helpful Ratings Feedback is appreciated,thanks paul7of9”
Feb 17, 2010 | HP Pavilion dv6000z Notebook
Error message ntdlr is missing running XP service pack 2
do a system restore from the system repair when you first start it up it should tell you what key to press once you get into system repair you can use system restore to fix the problem or either go to safe mode and do it from there then it will fix your problem
Aug 02, 2009 | Acer Aspire One AOA110-1588 Notebook
Optima getting fan fail error what can I do?
its eather it is dusty or the fan morter is burn out.
Jan 04, 2009 | Optoma EP739 Multimedia Projector
Error message Fan Failure press f1
Some of those OEM systems have built in fail safe's like that to try and keep them running longer w/o failing. Just get a hold of Dell and get a replacement fan, they should send instructions on how to put it in yourself! :)
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
Change initial message on Axxess PBX
By initial message, I assume you are talking about the auto attendant message heard when dialing your main line
To change the message:
1.  Dial the voice mail extension number, then press "*" when you hear the greeting.
2.  Enter the system administrator mailbox number and password.
3.  The system will tell you how full the hard drive is...press "9" to skip and enter the system menu.
4.  Press "3" for the custom recordings.
5.  Then press "1" to record or edit the messages.
You will need to know the recording number of the message you want to change.
Sep 08, 2008 | Inter-Tel Axxess Corded Phone
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Tower change
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Mar 29, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Onetel magma 400 phone / answering machine
Hey! To play messages press the clear/mute button then the number 2 button and then press the green phone symbol then your messages should play. To turn off do exactley the same but instead of pressing number 2 press number 8! Hope that helps!
Mar 02, 2008 | Lands Phones
HP Pavilion a1410n (ER890AA) PC Desktop Logo
832 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
