Question about Dell ST2320L Monitor
Monitor screen goes blank intermittently
Was working on my macbook air with dell monitor and it goes blank after a while and i have to touch the on button to activate it again. It keeps saying power safe mode or something. Thanks for your help.
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
  • 53 Answers
SOURCE: Dell E152FPc Monitor powers up, and screen goes blank in 5-10 sec
ok every one there is a fix the are 4 transistor 2sc5707 and 2 transistorfu9024n and i cap 16v1000uf
if you replace these your problem will be fix for a while but to it better then dell replace the 2sc57o07 with radio shack tip3055 they are 15 amp trans instead of the low 8 amp dell uses they fail because the amps at the test for the transistor is more than 8amps all the correct parts are sold in a kit on ebay look up the 2sc5707 but i recommend upgrading to the tip3055 transistors they are a bigger transistor but you can lay them down and they work great. the capicator can be found at radio 35v1000uf is a good replacment make you monitor better because the new parts are stronger then the originals so no more failures after.
Posted on Feb 20, 2009
SOURCE: Dell E193FPC
MY MONITORIAL LEAGUE AND 3 SECONDS LATER GO BELOW ARE BLACK BEING OR CONNECTED TO THE COMPUTER WHICH IT CANNOT BE HELPS ME TO THE PROBLEM I AM NOT IN CONDITIONS TO CHANGE OF MONITOR NOW AND ADORE THIS WAY OBLIGED THE MODEL DELL E193FPC
Posted on Jun 13, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
  • 1684 Answers
SOURCE: Dell E173FPc monitor worked fine yesterday.
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
Testimonial: "Excellent site"
Both Safari and Google Chrome internet browsers are intermittently working.
Have you looked at activity monitor when this happens?
perhaps restating the app from here will be better option than reboot
Feb 04, 2016 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
Laptop screen goes blank
If the monitor hookup solves the problem it means the inverter board located under the screen is intermittent, or the baclight behind the display may be the issue, and you may have a loose video cord from the screen to the motherboard plugin. But if both screens show the same symptom, it is the video graphics chip built into the motherboard.
Jun 19, 2012 | Dell Inspiron 1525 Notebook
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Monitor goes blank.
http://www.fixya.com/support/r4713866-moniter_blank
May 08, 2010 | Dell E173FP 17" LCD Monitor
Monitor screen goes blank at intervals. If I turn
You may have to open it up and look for bad soderling works, see my pictures to see what bad solderign joints look like. Also check fuses, connectors, etc.
See what goes wrong with Dell monitors here:
http://s807.photobucket.com/home/budm/allalbums
I assumed that it does the same with other PC also.
Apr 05, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Dec 16, 2009 | Apple MacBook Air
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell ST2320L Monitor Logo
Alun Cox
