How to turn on the tv with the onkyo rc 620m remote
IrishDruid
  • 2712 Answers
SOURCE: Onkyo remote RC 570M
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: remote control codes
What code do I need for a (RCA) RCR312W control to operate a Magnavox, model 63794526 TV?
Posted on Jun 23, 2008
The Machine
  • 788 Answers
SOURCE: Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Posted on Mar 30, 2009
  • 208 Answers
SOURCE: philips TV 42pfl9664 remote control interferes Onkyo
HI it is entirely possible that the function you are using on your tv has the same command that your Onkyo uses for selection of GAME-mode. You should be able to prove this by using the Game-mode button on your Onkyo remote and it should affect your TV.
If Not then try shielding the remote receiver on your stereo with something thick ( a piece of paper is transparemt to IR - use a book or pillow) and see if the problem clears.
If this test proves correct, then the only solution is to see if you can change the remote command ID on the stereo and remote (if it supports it). The philips will most probably not have this feature. otherwise the only solution is to upgrade 1 device for a different brand.
Posted on Mar 21, 2010
Macklintok
  • 122 Answers
SOURCE: I have an Onkyo DR-S2.0 DVD Receiver that will not...
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
Posted on Sep 14, 2010
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
Tip
Onkyo RC-682M Remote Codes
Download Onkyo RC-682M Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo RC-682M Remote Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo RC-682M Remote Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Onkyo receiver codes
Hi! Below a link where you can find the codes!
Hope I could help! Onkyo RC 620M
Dec 04, 2014 | Onkyo RC-620M Remote Control Part...
Remote codes panasonic tv for onyko rc-693m
What you really are requesting is the Onkyo remote codes to control your Panasonic TV. The code comes from the remote, not the TV
Dec 04, 2012 | Onkyo RC-693M Remote Control Part 24140693
Cannot regulate sound volumn from Onkyo RC-620M remote
If the protection key like child lock is activated, volume might get locked. If it is changing on the device and not through remote and all the keys are functioning, the problem is in the remote control. Might require thorough cleaning inside or go for a replacement.
Jul 04, 2012 | Samsung Televison & Video
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
May 21, 2010 | Onkyo RC-549M LCD Remote Control
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
The remote all of a sudden quit working.will work
needs to be reprogrammed do you have your manual
Jul 01, 2009 | Audio Players & Recorders
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
