Question about Ingersoll Rand Electrical Supplies
Want stay running
I have a 25kw generator diesel when warm the glow plug and crank it it goes dead I can hold the key over and it will crank again as long as I hold the key in the crank position it will continue to crankand go dead. I can get someone to crank it and hold the fuel shutoff up it will stay running and shows power being put out
protek480
  • 1714 Answers
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Posted on Jun 26, 2009
  • 297 Answers
SOURCE: Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Posted on Jul 15, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Colman Powermate Generator will not stay running
This overflow can be caused by:
1. The float sticking
2. Gas inside of the float air chambers
3. The needle and seat have debris in them or a r damaged.
It is not a difficult fix but it does mandate removal of the carburetor float bowl.
You could probably do this yourself. It is much easier if you place the generator on a high work area so you can see the float and needle once you have the float bowl removed. Just make sure you do not drop the float assy so far that the needle comes out of the seat unless you have to remove the hinge pin SCREW for the float to clear the debris near the needles' pointed rubber head.
Thanks for using FixYa
Kelly
Posted on Mar 22, 2010
I have a 1994 f 350 turbo diesel IDI when I try to
Don't just keep cranking if it don't start right away' Give the starter a break. It's getting hot because you just keep cranking on it. Any vehicle diesel has glow plugs to heat the fuel chamber to make it start fast. Be sure you are making use of the glow plugs and it will start fast. If your glow plugs are not working, find out why. Could be just the glow plug relay or connection to it. Or possibly the glow plugs are burned out. Either way, you HAVE to have glow plugs in use on a diesel upon initial start up till it's warmed up. Then will start without them. Most are automated system. You just have to wait till the glow plug light goes out to start cranking on it. I hope this helps you to more understand the workings of a diesel cold start system.
Sep 25, 2014 | Cars & Trucks
Why does my 2004 (Land cruiser) PRADO 3000 Turbo Diesel 5sp- have issues starting when it's cold? It turns over and over does nothing, then when it starts, I get a big plume of smoke, then it idles rough...
glow plugs are activated if look on the dash when you turn the ignition just before cranking and you should see a light that stays on for several seconds then goes out and then you should crank the engine ! sometimes when its really cold or the glow plugs are worn try turning the ignition on and off each time light goes out 2 or 3 times to get more heat on the plugs then start ! if this doesnt work then glow plus and system needs checking !
Sep 02, 2014 | Cars & Trucks
Preglow diesel
The glowplug is designed to heat the diesel fuel prior to cranking. Typically you energize the glow plug for 10-30 seconds then hit the starter. If the battery is weak or it is very cold, you may have to run the glow plug a little longer.
Apr 15, 2014 | Electrical Supplies
No cold start
Well first of if it cranks slow, make sure the correct battery voltage is being applied. IS the pre-heat function working? If that is not it won't start when cold. Also check oil viscosity is correct. If the pre-heat is working make sure glow plugs are getting warm on each cylinder.
Jan 24, 2014 | Onan Cummins 10.0 HDKCA/11506 RV QD 10000...
Mercedes class 200 cdi. when i start the car the glow plug lights stays on for couple of mins then goes of?????
This is normal, the glow plugs are building heat in the cylinders to help ignite the diesel. They should cycle off and on until the engine warms up.
Aug 27, 2011 | Mercedes-Benz C-Class Cars & Trucks
I have an 1993 Ford F250 turbo diesel truck that won't start. I've been told, that the glow plugs are not warming up. Where are the glow plugs and is there anything I can do to warm them up or fix? Do they...
Are you waiting after turning ignition key on before actually moving key to start position? My diesel I turn key to 1st position;bells and lights;if engine is cold an amber light that looks like a lamp filiment comes on...wait until that light goes out before engaging the starter.
Oct 18, 2010 | 1993 Ford F350
1997 VW JETTA DIESEL GLOW PLUGS
The glow plug relay is responsible for the duration of glow plugs, this needs to be the starting point. You should get a 12v out for so many seconds when ignition is switched on.
I have taken the cover off relays in the past, cleaned up the internals, sprayed with circuit cleaner and got plenty more years out of them, worth a try.
Nov 21, 2009 | 1997 Volkswagen Jetta
I have a 1998 1.8 diesel van, once its running its ok, but getting it started can be difficult (esp in cold/damp) Have you got any tips for starting, does this model have a heater plug, if so what symbol...
Sounds like the glow plugs are frazzled. There is one electrical wire going to a plug, then each plug is connected in sequence. The glow plugs are heating devices used to get the fuel up to temperature before ignition.
They are fiddly to replace, but are relatively inexpensive and the most common source of issues with cold-starting diesel engines (first thing to fail).
Some cars had a 'pre-heat' available with glow plugs, where you simply turn the key part-way to 'on' and you would see a glow plug light come on (looks a bit like a picture of a spring). If you see this light on your van, you can turn the key to turn on the glow plugs and they will pre-heat your engine slightly and make starting easier
Nov 10, 2009 | 1998 Ford Escort
7.3 l diesel wont start
Bad glow plugs and/or glow plug controller. Common issue with these vehciles. Some also have harness failures. Replace all glow plugs as a set not individually.
Mar 29, 2009 | 1991 Ford F250
Truck fails to start
The 01 DuraMax trucks do not have a block heater, unless they were special ordered with one. Just turn the key to the on position a few times before you try to crank it, and hold the accelerator partially down while doing it. However, don't hold the accelerator if it starts to crank, it DOES need a minute to warm up before being revved. Also, use a diesel treatment when its cold, it helps a lot.
Jan 17, 2009 | 2001 Chevrolet Silverado 2500HD
Electrical Supplies Logo
37 people viewed this question
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
