Question about John Deere Garden
John deere irrigation motor with lucas injection pump won't shut off.
Had john deere lucas injection pump rebuilt, also rebuilt motor. the engine starts and runs fine but won't shut off. I checked to see if 12 volt power source at shut off solenoid was being shut off by 117 switch and it is. Have to shut off fuel and let it run out of diesel to shut off.
5 Suggested Answers
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
nova2nv
  • 197 Answers
SOURCE: john deere tractor x585 not getting 12 volts at fuel pump
To check pump u remove fender deck,unhook connector, put 12 volt power to it.I have seen pumps react to a swift kick to the fuel tank,NO JOKE.You first have to check fuses,2 on control board and early x585 machines had a single red wire near control board that was only for fuel pump.Remove right side air screen and check for voltage on the relay closest to the radiator.Red wires #231/232 feed your fuel pump relay.Current flows from that relay #655 pink wire and goes to your fuel pump .Also check#215 grey wire {fuseable link}coming from starter post,they WILL burn out,it goes to #221 red wire with inline fuse and feeds rear of the 2 relays,that is your EFI relay.You have 3 fuseable links coming off starter post,check all of them.
Posted on Jan 01, 2010
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
SOURCE: john deere 4010 wiring schematic,diesel engine
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Posted on Dec 24, 2011
My john deere 1070 loads up under a load and will stall. I changed fuel filter which was loaded with "gunk" and it ran ok for a while then is doing it again.
I am not sure what you are calling gunk but if this gunk is black it is engine oil. The tractor and the engine was built by Yanmar. The injection pump is lubricated with oil pressure from the engine. The seals in the pump will leak and engine oil will get in the fuel system and contaminate the diesel fuel and plug the fuel. Seals will have to be replaced in the injection pump to correct the gunk.
Nov 08, 2016 | John Deere Garden
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
Can't remove fuel injection pump from block
John Deere makes a good product. I was wondering why you are trying to remove the injection pump.
I have seen more problems with a broken fuel line then motor related problems.
If the injection pump looses its prime (air bound) it needs to be reprimed. The lift-pump on the side of the engine, have you inspected that?
What have you done so far that has lead you to believe that the injection pump is bad?
If you go to the section of the repair manual for injection pump timing, there you will find the answer for removing the injection pump. Let me know how your making out.
Apr 29, 2010 | John Deere Tractor Side Screen...
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a 1969 John Deere 4020 that is cold blooded. It turns over fast, but won't start without being pluged in or using ether below 70 degrees. What are the potential problems?
Cylinder Compression Low, Valves worn ... not seating properly, valve stems.
Injector nozzles worn ... dribbling rather than precise squirts, injection pump worn.
First and easiest thing to do: pull all nozzles and have them tested, pull the injection pump and have it rebuilt and re-calibrated.
*NOTE: you can pull these, but are components that proffessional need to rebuild and calibrate. Truck shop, or farm tractor shops have places that specialize in this type of work.
If it is gasoline, I would look towards pistons, rings, valves.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 445 with 22 hp kawasoki engine wont run take 1 plug out it runs dont mater what side stick finger in plug hole engine shuts off ,but wont start with both plugs in
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Sep 03, 2009 | John Deere Garden
Garden Logo
14 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
