Question about Mitsubishi WD-82738 DLP TV
Mitsubishi wd82738 turns on but no picture and then shuts down
What is wrong with Mitsubishi tv Model WD:82738? I just replaced the lamp and it is making a sound like a bearing rubbing and the picture is flickering.
It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
May 23, 2016 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Why does our mitsubishi wd-82738 turn off after about a min
Power supply regulator board fault. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 25, 2014 | Mitsubishi WD82738 82 1080p 3D DLP Home...
WD-82738 82-Inch six red blinks one yellow blink replaced chip to fix white pixels issue.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Blinking code detail, and fault finding procedure to many brand TVs are given. Pull up older posts.
Nov 29, 2013 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
My picture blinks every few minutes, three or four times and then is fine for a few minutes before it does it again
It sounds that the main power supply regulator's output voltage varies more than normal. Being a 3D TV, it will be best to contact the authorized service centre for Mitsubishi. The TV have very complicated circuit inside, and it will be risky to open it or try to do anything with its boards. Might make the TV irreparable. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 10, 2013 | Mitsubishi WD82738 82" inch 3D Ready DLP...
82" Mitsubishi DLP tv Picture Blinks every few minutes
your Lamp is on the Way out. You will need to replace this in the Next 4 months, This is the First sign of the Lamp failure. How old is the TV?
No picture with sound tv turns off. Mitsubishi model WD65837
are any lights lit up when it shuts down? If so which light what color is it and is it blinking or a just stays lit without blinking?
Apr 05, 2013 | Mitsubishi WD 65837 TV
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Mitsubishi WD-82738 DLP TV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
