Frisby FMC 220
How do i install this on windows 8 HP computer? Add new hardware wizard never popped up
ThaMp3Doctor
  • 8596 Answers
SOURCE: my computer wont recognize my 30gb black zune
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 06, 2008
SOURCE: Installing Hardware
i need to down load my logiteck notebook cam driver please
Posted on Sep 06, 2008
  • 136 Answers
SOURCE: I cannot enable my wireless adapter
the drivers needed updating, got to love Windows.
Posted on Dec 20, 2008
SOURCE: I have an OnStream Echo USB 30GB tape drive that
Send me an email, and I'll forward the XP sriver that I bought.
Posted on Oct 30, 2009
jepito
  • 216 Answers
SOURCE: I have a new, just out-of-the-box Seagate
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Your hard drive is now ready to be formatted.
Formatting Your Drive Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on
Posted on Dec 24, 2009
My Officejet Pro 8500 Wireless will not print in landscape mode no matter what I try. Last time I had this problem, HP had me install a generic printer; but I don't remember what exactly I had to do...
here's how:
FOR WINDOWS XP:
  1. Click Start .
  2. Click Printers and Faxes folder.
  3. Click File . Then select Add printer . NOTE: This step launches the Add Printer Wizard .
  4. Click Next .
  5. Uncheck the Automatically detect and install my Plug and Play printer checkbox.
  6. Click Next . The Select a Printer Port window displays.
  7. Click Next . The Install Printer Software window displays.
  8. Select HP from the Manufacturer list .
  9. Select hp deskjet 990C model from the Printers list.
  10. Click Next . The Name Your Printer window displays.
  11. If the printer name is correct, click Next .
  12. Click Next . The Printer Sharing window displays.
  13. Select No when the message Do you want to print a test page displays.
  14. Click Next . The Completing the Add Printer Wizard displays.
  15. Click Finish . NOTE: At this point, the driver installation portion of the process is complete.
  16. Connect the USB cable to the printer and the computer. NOTE: Windows will start to Plug and Play the device.
  17. Click Cancel for each Found New Hardware Wizard window that is prompted. NOTE: The number of Found New Hardware Wizard windows prompted by Windows will vary depending on the device plugged into the computer.
  18. In the Printers and Faxes folder, click the hp deskjet 990c printer icon.
  19. Click File . Then click Properties .
  20. Select the Ports tab.
  21. Scroll to USB00x Port and check the checkbox for the port.
  22. Click Close .
Jun 03, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Downloaded the software from HP for my PSC 1350 All-in-One, and it ran on my XP machine, got to 100% extracted, then the screen just went to my desktop..... No action..... No install wizard. No indication...
it is very possible that because you have another hp printer active with that computer, and the software from the new hp printer may be conflicting with the software already installed into that computer, and becuase of that, the computer automatically drops the new installation of the software from the new printer, just like it never happened, in almost any case, you will have to uninstall the whole software program from the other printer already installed into that computer, and install the new software into your computer, if that still doesnt work, then your new printers software, the new printer, or both are not compatable with your computer
Jan 21, 2011 | HP PSC 1350 All-In-One Thermal Printer
How do I get and install the codec Intel IMA ADPCM (11)
Hi There,
The codec should already be there.
Just follow these steps:
1. Click on Start -> Control Panel.
2. Click on Add hardware applet.
3. On the Add Hardware Wizard, click on Next button.
4. Select “Yes, I have already connected the hardware” radio button and then click Next button.
5. Choose “Add a new hardware device” at the bottom of the list and then click Next.
6. Select “Install the hardware that I manually select from a list (Advanced)” and click Next.
7. Select “Sound, video and game controllers” from “Common hardware types” list and click Next.
8. Select “(Standard system devices)” from “Manufacturer”.
Note: To install or reintall video codecs, select “(Standard system devices)” from “Manufacturer” and “Video Codecs” from “Model” instead.
9. Click on “Have Disk…” button.
10. Click Browse button in the Install From Disk dialog box. Navigate to folder C:\Windows\System32, and then locate mmdriver.inf file. Highlight mmdriver.inf and click Open or simply double click on mmdriver.inf file, then click OK in the Install From Disk dialog box.
Click on “Continue Anyway” button if a warning about logo compatibility pops up.
11. A list of audio codecs supported by mmdriver.inf appears on the Add Hardware Wizard.
Aug 27, 2010 | Intel Computers & Internet
I have XP. Recently I tried to install a new printer (Kodak). A window kept popping up stating it was not compatable with the windows program. I called Kodak for help and was told the computer I had (which...
You might have installed the drivers recently with the "found new hard" wizard without selecting "No, Not this time".
Once the "found new hardware" wizard pops up, don't close it or cancel it, rather leave it and directly go to your device manager, expand all the snap-ins and locate any device link with yellow highlighted question (?) mark. Make sure in which device's category it is listed, and install the driver from the "found new hardware" wizard by selecting "No Not this time only" before you proceed to the next step.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Microsoft Computers & Internet
I have no installation disk
The printer driver can be downloaded from the printer manufacture's WEB site.
If you do not know the WEB site, then please let me know the make and model of your printer and the Windows version that is installed on your computer.
Mar 31, 2010 | Office Equipment & Supplies
How can I make my printer compatable with windows vista.
Windows Vista has the basic drivers for HP deskjet printers. Please follow the steps below:
1. Just turn off your computer, and then connect the parallel cable to the computer and printer.
2. Turn on the computer. You will be prompted to a Found New Hardware window.
3. Select Locate and Install Driver. Make sure to click Allow if the User Account Control screen pops up.
4. Windows will search for the drivers, if it was able locate the drivers then the installation is complete. If not then click Cancel.
5. Go to Control Panel -> Hardware and Sound -> Printers. Select Add Printer.
6. Click Add a local printer. Then click Next.
7. Select Use an existing port. It should be LPT1 (Printer Port). Then click Next.
8. On the Install the printer driver screen, select HP in the list of manufacturers. Then select the model of your printer. If it is not listed, click HP Deskjet 500c. Click Next.
9. Type the name of the printer, then click Next. The printer driver installs. You may click Print a test page to test if it is working.
10. Click Finish.
I hope this helps! Good luck!
Jan 22, 2010 | HP DeskJet 5550 InkJet Printer
Cannot find my cd installer for hp deskjet d2360. trying to download for free installer. can anyone help?
If you have internet access go to hp downloads from google. If not, connect your printer to your PC (computer) turn it on. If your OS is XP the found new hardware balloon should appear above the icon on the task bar, click the balloon and the add new hardware wizard comes to the screen, read and follow prompts, as it will give you a list of some recent and current hp printer products to choose from. If the balloon as mentioned above does not appear, click start, click control panel, double click add hardware icon, and the add hardware wizard comes on screen, choose your options and follow the prompts. NOTE; if the printer has been installed on your computer previously, and your OS has not been altered (formatted) this is an easy task for the wizard, as there is a shadow copy of the necessary drivers stored in the memory of your hard drive. Hope this helps.
Jul 10, 2009 | HP Deskjet 2360 InkJet Printer
New comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4.Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select "Deskjet 5600"
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Now let's configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
2. Click Print Test Page
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
Scanner does not work
First make sure that the scanner drivers and all the PSC drivers have been installed.
Or try to reinstall the printer drivers by removing all Hewlett Packard's applications from "add - remove programs" in the control panel. Then disconnect your printer and restart the computer.
When the PC finishes loading windows, insert the HP printer software CD while pressing SHIFT on the keyboard for 30 seconds. Connect the printer again and follow the "Found new hardware" wizard instructions. When a gray sandglass pops up, choose "Decline" or "Not agree" to the license terms and continue with the installation.
After that, try to scan again from Photoshop or another scanning program. Remember that in the reinstallation, you haven't installed the HP image zone software.
May 04, 2008 | HP PSC 950 All-In-One InkJet Printer
HP 5550. Stuck in install loop
uninstall previous printer driver and resintall again the cd driver
Feb 01, 2008 | HP DeskJet 5550 InkJet Printer
239 people viewed this question
 Grubhead
Grubhead
