Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to turn off the commentary for the blind on a westinghouse tv
How do I remove Blind Commentary from my Westinghouse, flat screen television?
get the on screen menu up , navigate to the section for audio , turn off any blind help or assist , go ok and exit
May 26, 2016 | Westinghouse Televison & Video
It's like a blind setting or commentary setting. I want to take it off and watch my dad normally
You asked,
" Its like a blind setting or commentary setting. I want to take it off and watch my dad normally."
I can't make sense out of this question.
Are we getting a partial conversation here? Is this part of a discussion that you started with someone else?
Mar 09, 2015 | Televison & Video
Turn off commentary for blind people
The secondary audio program (SAP) can be disabled by returning to the initial set up routine.
Feb 24, 2015 | Humax FOXAT HDR DTV Receiver
We have running commentary in the background of programs
Sounds like you may have accidentally set the SAP on your TV, or you have the commentary track set to on on your DVD player.
In either case, easy fix. If you have a SAP button press that and see if it helps. If you do not have a button there should be a setting under sound in the TV menus.
For the commentary on DVD you should be able to go into the DVD menu and select Audio/Sound and make sure commentary is not selected.
For any further assistance I will need more information on your issue
Apr 06, 2014 | Televison & Video
How to stop blind commentary on my samsung tv
Press the button marked "CC" at the remote control, once to stop this. If there is no such button on the remote control, enter its menu, and select the Closed Caption option, and make closed caption function to OFF, if it is set to ON now.
Sep 23, 2013 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I turn off commentary for blind on Sony Bravia TV
You're asking about how to stop the closed caption option, I assumes and posts this solution. Check whether thee is any button in its remote control marked [CC]. Press it once, if it is there. If there is no such button, you have to enter its menu, and select functions. Find out whether Closed Caption function is On. Made it OFF.
May 27, 2013 | Televison & Video
The vocal commentary for blind people has switched itself on. how do we switch it off?
It may depend on the model. Usually this is in the SAP options. It may be adjustable in the Quick Menu. Otherwise, enter the Menu > SAP (if an analog channel). Press Enter and then select SAP, Mono or Stereo and then press Exit.
If you are watching a digital source, then Menu > Multi Audio. Press Enter and then choose the language/content and then press Exit.
This is for the 32LD550. If you have a different TV, try LG's site: http://www.lg.com/us/tv-audio-video/televisions/index.jsp . The manuals are available for many of the TVs.
I hope this helps.
Jan 29, 2011 | LG Televison & Video
How do i remove the commentary on my samsung lcd tv monitor, this guys voice tells you what is happening in the programme, it may be for people who are blind but i want to take it off can you help me it is...
First off I need the exact model of the tv. Depending on if you have closed captioning on the monitor or on the source you are outputting to the monitor. Just turn Closed captioning off. If it's a dvd player make sure it's off on the dvd player. If it's a cable box make sure it's off on that. If you need further assistance let me know.
Thank you,
Lee
Aug 17, 2010 | Samsung Televison & Video
Commentary
Make sure that the closed captioning is turned off. For text and for audio i would suggest check in menu in the audio section for possibly SAP (second audio program) or something similar to this to disable that feature. Let me know how it goes. Jay
Dec 20, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
