Question about Intel (P42000400512SK478) Pentium 4, 2 GHz Processor
My pc always hang...
When i start my pc it run normally but when i restart then it will hang.
it started when i opened the fan of the processor and i clean the processor by brushing using cloth which accidentally removing the black powder or something on the back of the processor ! did i damage the processor by doing that? what shall i do please help me? I think the powder or something i removed was the coolant of the processor, am i correct?
thanks.
cornelio of philippines
    Sergeant:
    Novelist:
  • 143 Answers
If removing the black powder was damaging to the processor then your system wouldn't start at all.
If I am interpreting this correctly, your PC is only hanging when you restart. It sounds like what you did was pull the heatsink and fan off of the processor and you wiped away that black powder/smudge junk that OEM vendors such as HP use as thermal material between the heat sink and processor.
Some systems do that. It's to be expected. It COULD be caused by a temperature sensor detecting higher temps, though. (Although that's not likely if it's still starting when you shut it down completely and then start it back up.)
The first thing you want to do is re-seat the CPU in it's socket. I don't know what kind of CPU you have so I don't know what kind of socket it is. Be careful in doing so and if you don't know how to open and close the socket then do a little research online for some instructions; or come back here and tell me what kind of CPU you have.
After re-seating the CPU correctly, you want to be sure to clean the die of the CPU with some kind of solvent (such as alcohol) to get rid of any grease or random chemical build-ups. If there is still sticky residue on the CPU from the thermal material, you can normally get rid of that using a bit of WD-40 on a cloth. (DO NOT APPLY ANY CHEMICALS DIRECTLY TO THE DIE OF THE CPU. PUT IT ON A CLOTH FIRST.) If you use WD-40 to clean the CPU die, use alcohol to clean up the WD-40 afterwards.
Do the same to the bottom of the heatsink. Apply WD-40 directly to the bottom of the heatsink if you like. It tends to eat away all of the sticky junk well enough that you can just scrap it off. Clean the surface with alcohol afterwards.
Get yourself some thermal paste from either Radio Shack or an online store. (Radio Shack is currently selling Arctic Silver thermal paste. Good stuff.) Apply just a SMALL DAB of it to the die of the processor and spread it around until you have a nice, thin and even layer of it. (You don't need a ton of it on there.)
OPTIONAL STEP FOR BETTER RESULTS:
If the heatsink is rough on the bottom of it, you can buy sandpaper and sand the bottom of it flat and smooth on top of a flat, glass panel. Make sure to give it a good, smooth finish with a fine sandpaper. This will give it a good, flat surface to make contact with the CPU and will help thermal transfer a great deal. Clean the heatsink and apply it to the top of the CPU carefully.
MAKE SURE THAT THE HEATSINK IS NOT FACING THE WRONG DIRECTION WHEN YOU PLACE THE HEATSINK ON THE CPU AGAIN. If you do, it may actually sit on the socket that the CPU is in rather than on top of the CPU itself. If you turn it on like that, you may burn the processor.
Lock the heatsink down onto the processor as normal.
That junk that OEM vendors put on CPU's should be banned. It's better than nothing...but not by much. They tend to use junk heatsinks and even worse thermal transfer material.
I doubt you damaged your CPU by taking off a little bit of the thermal material like that. However I'm not saying that it's not possible, either. It most likely just got a little bit hot afterwards if anything.
At the very least, clean the surface of the heatsink and the CPU and put some thermal paste there between them. Things should run fine after that. But if your system continues to hang on a restart, then I wouldn't panic. Mine does that sometimes. No big deal. I just shut it down instead of restarting it and turn it back on.
Either way... If you follow these instructions and have a better cooling situation, you're going to experience a bit more stability and possibly better performance with your system.
Let me know how it goes.
Cyryl
Posted on Nov 02, 2007
    Problem Solver:
  • 6 Answers
It seem many thing you must see.Maybe your pc have a virus.You can use Spyware Doctor or other software.For best solutions, you must open use safemode cause many virus inactive when you open in safemode.The other way, maybe your cpu too hot, you can follow what cyrylthewolf suggest.Hope you can try.
Posted on Jun 30, 2010
HI
my XP-Home system always give ganging problem
Posted on Jan 28, 2010
Clean your memory using eraser scan your hardisk
Posted on Oct 19, 2009
Why my computer always hang
i dont know the problem what im going to do
Posted on Sep 25, 2009
Hardware errors
you processor got heat there is dust in processor fan you have to clean it
Aug 03, 2013 | Fujitsu LifeBook Computers & Internet
My Dell Dimension 8440 shut down it self And I can not restart
it is very possible that if the pc has been sitting long enough, that there is dust build up and the processor simply overheated. try opening the side of the cAse and clearing any excess dust. might want to check your connections if possible. computers are not an exact science so strange things can happen!
Dec 31, 2009 | Dell Dimension 8400 PC Desktop
My computer always hang, then i always restart it until it will function normally...whats the common problem for it? so that i can fix it immediately..
There a lot of unused files in your PC. Just install the
Tune Up Utilities of 2008. Once installed Click open
Tune Up 1-Click Maintenance. This will erase the unused files in your PC. Furthermore, Also install
Your Uninstaller of 2009. Once installed, Click open,
1 - Click Cleaning to clean your PC further. Both programs will correct your problem.
You can connect to the internet and get the download
one at at time. Just type at the Search engine blank
(Free download of Tune Up Utility of 2008) and Click
the search engine. Once you get to the site, click
at the free download) Once you have the download,
install it in your PC, by clicking it open.. Once installed,. Click open the 1-Click Maintenance at the
desktop. Follow the same procedure with the Your
Uninstaller of 2009 download.
I'm pretty sure, this will speed up your PC and no
more hang up.
Furthermore, always keep your anti virus software
updated, and run the virus scan to keep it on tiptop
condition.
Nov 22, 2009 | Computers & Internet
Intel D865 GBF system hangs oftenly
Hello,This always happen when the processor is bad or faulty. when the system is working, check if the processor fan is working too, if the processor is working that means the CPU is faulty.leave the system open and power it on to see if it will hang.
Aug 11, 2009 | Intel D865GBF Motherboard
My desktop PC Windows XP Pro hangs during resart only
try to use msconfig (on run) to see what programs run on system startup. some of these programs may be a malware that keeps on placing trash on your computer. i would recommend you download the Anti Malwarebytes and run it to remove the suspected malware.
regards.
Jul 15, 2009 | Computers & Internet
Hi there I have a dell computer and I
it is the simple problem of your motherboard you can go to workshop and then checked your RAM and processor fan and it's chipset
Jun 28, 2009 | Dell Computers & Internet
Sony PC
is it fixed 15 mins or its a round figures. does i happen without any fix time. the options are normal like save mode, normally etc...
have u checked ur processor's fan. is it normal or resists to run. it can happened b'coz of it also. also check ur ram too.
regards,
Jul 31, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Motherboard_prob
just check is the processor fan is running or not then try with new ram,power supply,
Jul 21, 2008 | ASUS Computers & Internet
Cannot continue
Well...
I am VERY confused by your description here. I can't tell if you're talking about the processor as it appears inside of your computer itself...or if you're refering to the processor as it appears in Windows.
Please try to be a little more specific with your explanation. Go step-by-step in what you are doing and what is happening.
Cyryl
Oct 31, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Intel (P42000400512SK478) Pentium 4, 2 GHz Processor Logo
2,499 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
