Question about Camping, Backpacking & Hiking
Nordic retreat hot tub electrical issues
I just bought a New Nordic hot tub (retreat/220V) GFI breaker keeps tripping immediately. Checked all connections from panel box, all good there. So ******. Any ideas???
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 351 Answers
SOURCE: Our hot tub keeps tripping the gfi breaker, but if
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Posted on May 12, 2010
volpe_42
  • 35 Answers
SOURCE: Gfi Breaker 2 Pole 20 Amp: installed 20 amp dbl pole breaker to hot tub. Keep...
When Working with Household Electricity you want to always keep in mind that the BLACK wire ALWAYS carries DEATH. What I mean by this is that working with a Single Phase Circuit (one that uses 120VAC) the only wire that should be carrying a voltage is the BLACK one, the other 2 wires (typically the White Neutral and Green Ground) should both be electrically connected to Earth Ground (usually by being attached to your water pipe.)
It is also possible that your hot tub may use more than 20 Amps.
Posted on May 19, 2010
  • 5089 Answers
SOURCE: What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Posted on Oct 02, 2012
johnthomp55351
  • 3 Answers
SOURCE: 1999 Artesian hot tub heater keeps tripping electric breaker
read the pump motor tag. it should have wattage consumption. if u have already been running it, ensure breaker is pushed all the way in. and u don't have a new appliance running on the same breaker.make sure the grounds are clean and tight.thats all I can think of. if persists,use a multi meter and start testing.
Posted on Jan 02, 2015
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Oct 02, 2012 | Electrical Supplies
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high...
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
May 08, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
I have a 240V hot tub and when I turn on the Cutler-Hammer GFCB250 GFI Circuit Breaker, 50A, it trips immediately. I spoke with a tech support guy from the hot tub mfr who says that the heater and pump...
It is very possible breaker is bad. If you have another 50 amp breaker in the box try swapping them and see if it still trips. GFIC breakers are finicky and they do go bad. I would make sure that the heater is not shorted out before replacing the breaker. It shows 15 ohms which is not what you would normally see which is 9-12 ohms. The reading of 15 ohms you got is high but if the manufacture says that is acceptable then we must assume it is. You also need to test for a short before eliminating the element as a possible cause. Test it with your ohm meter set to the highest setting. Measure between one element terminal and the sheath of the element. Any reading indicates a short to ground indicating the element is bad. If you find it is good then a defective GFCI is really about all it can be.
Sep 20, 2010 | Eaton Corporation GFCB250 GFI Circuit...
May 17, 2010 | Cutler Hammer Gfi Breaker 2 Pole 20 Amp
Our hot tub keeps tripping the gfi breaker, but if we don't put it on a gfi then it works fine. How do you fix this
Please Vote !!
Apr 19, 2010 | Balboa Instruments Duplex Digital Panel 2...
Spa keeps tripping breaker. Not GFI. Ran for 2 years then problem started. Replaced breaker. Where to look next?
Sounds like wiring problem, rule out GFI sometimes they just go bad or have your wiring checked in that run something is not hooked up correctly or loose. Make sure this circuit it is not shared with anything else. If not ran for 2 years could be wiring problem in spa get it checked out be safe, water and electric bad news if your not familiar with or comfortable with electrical issues. Good luck!
Oct 14, 2009 | Pool & Spa
Hot tub breaker keeps tripping
You are exatly right. It's really not that uncommon for Older models to have faulty motherboards. Once you replace that, it should be working new.
Oct 12, 2008 | Sport & Outdoor - Others
Camping, Backpacking & Hiking Logo
483 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
