Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Porter cable 150# new compressor problems - Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
  • 1383 Answers
SOURCE: Crank bearing cap blew out on Porter cable air compressor
Your compressor is sold under various part #s depending on brand name. The link below is the breakdown for ac-0171.
http://www.devilbissparts.com/OilLubeStat%20PDF%20files/ac-0171.pdf. You will notice that there is no vent to release internal pressure. Most brands have a filler/dipstick which is also a vent. As the compressor wears there is a normal increase in crank pressure caused by pressure passing thru the rings. I have seen home made vents installed on the bearing cap. If you are creative you can make one yourself using the same cap or a metal cap (axel bearing cap) that fits the opening. A crankcase vent is a very simple device. A small hole to atmosphere with a bit of oil resistant foam behind to prevent oil from being blown out the hole. Works best when there is a vent tube about a couple of inches long to catch any oil and allowing it to run back down into crank. Remember that there is oil sloshing around inside the pump. Examine several brands of compressors for vent and try to recreate that on yours. One thing in common about vents is that they are usually located pretty high up above the crankshaft. You could also try lowering the cut-out pressure on your compressor to reduce back pressure. Good Luck on your repair.
Posted on Apr 23, 2009
webxcreation
  • 4 Answers
SOURCE: Porter cable pancake unit blows air after shut off.
tap on the check valve with a metal object. Its sticking open. The check valve is the brass fitting on top of the tank. When the valve sticks open it emits air from the area of the engine. If that doesn't work (which I would be surprised it doesn't), you'll need to purchase a new check valve. Good Luck!
Posted on Jul 02, 2009
atthings
  • 59 Answers
SOURCE: porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Posted on Jun 06, 2010
caroldon
  • 17129 Answers
SOURCE: My porter cable air compressor
The airr pressure cut off switch is not working or out of alignment. What you can do is to adjust the spring with the air pressure reading at your required pressure. Once this is done allow the air to flow so that the compressor will work again to cur off, you will have to trim once again to set it to the correct condition. If the spring assembly is not working well on pressure you can remove and reset. If the contact are dirty , the switch on may not start the compressor, in such case clean the contacts. But if you think that it is not acting responsive, the please replace the unit and do the settting as explained above.
I hope you try this out. Good day
Posted on Aug 16, 2010
SOURCE: my porter cable c2002 150 psi gal compressor the
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Posted on Dec 20, 2010
Porter Cable 150 psi 6 gal compressor tank builds up to 150 psi but 'regulated air' stays at zero and, of course, no air out. Thanks
The attached link provides a work around,
There are repair kits available. Dissemble and make sure that you document the assembly for reassembly. Common problem.
Hope this helps.
Fixing Porter Cable C2002 Regulator
Aug 13, 2016 | Porter Cable Air Tools & Compressors
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
Porter cable the compressor regulator is always at 0, the tank is at 150psi but no air at the outlets
Always at zero,like the regulator is broken?
I would assume that you never set it to whatever
pressure you want to use
Jul 31, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable c2002 150 psi gal compressor the pressure regulator is always set at 0 and no air at outlets, but the tank is fill of air 150psi. what could be the problem
Jul 10, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable stand-up air compressor starts but air won't fill up
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
43 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
