Replace dryer belt for Kenmore Model # 417-92702200
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
SOURCE: Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Posted on Jun 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Posted on Jul 23, 2008
dragonsthatk
  • 547 Answers
SOURCE: Replace dryer belt
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
How do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Apr 26, 2010 | Kenmore 62602 Electric Dryer
Trying to replace the dryer belt on a Kenmore Dryer
Good day,
That is a known defective part. Go to any appliance parts house and get the model with a wheel on it. The counter men will know what you need. Yes, it's made by Whirpool.
Directions below.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 05, 2009 | Kenmore Dryers
I need to replace a dryer belt on a Kenmore gas dryer model number 110.73032102. The belt part number is 2925.
Not sure where you got that part number but the true part number for the belt on your dryer is 3387610
The service manual detailing the disassembly and repair of your dryer can be downloaded at link below. Be sure to unplug dryer before proceeding to disassemble::
http://www.mediafire.com/?5gmg0jyji4t
Nov 05, 2009 | Kenmore Dryers
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
