Question about HP OfficeJet 6110 All-In-One InkJet Printer
Paper too narrow error
My officejet wont print or receive faxes because paper is too narrow. I have already checked to make sure that the settings are on letter size which is the size loaded. Please comment.
    Scholar:
  • 124 Answers
Have it save-to-image instead of print-to-paper. That should make it happier.
You can then print it out later, re-sizing it to fit the paper you have to print on.
Posted on Jun 18, 2009
Paper too narrow only receive fax
possible that the margins you are using are incorrectly set
Jul 14, 2017 | HP OfficeJet 6110 All-In-One InkJet...
I continue to receive "paper too narrow. load with wider paper" message despite using 8 1/2 x 11" paper. This was not an issue I've ever had before and am using the same size (standard) paper as I always...
Check the Paper Size Settings.
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
If you have a problem just reply on us.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I am trying to receive a fax and am getting a paper to narrow mes
I not really sure on this machine if it has these setting, but most fax do. There is a setting that allows you to automatic choose reduction of a fax if the one sent was larger than 8 1/2 x 11. Good Luck
Apr 22, 2009 | HP Office Equipment & Supplies
Hp fax/scanner # 6110
Hi Judy,
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Mar 04, 2008 | HP Officejet 9110 All-In-One InkJet...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6110 all in one.
This seems to be a pretty comprehensive series of steps to fix your paper too narrow printing and fax problem with the HP 6110.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpu00804&prodTypeId=15351&prodSeriesId=322818&locale=en_US
Nov 14, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
