Question about Hitachi Televison & Video
I have a Hitachi 51F510 & put my tv' on a antenna & have had no problems with doing the channel scan on the other tv's & are working great but can't get the Hitachi to bring up or find the channels when I scan
  • 375 Answers
SOURCE: Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Posted on Apr 13, 2008
SOURCE: Hitachi 51F510 51 in. rear
Maybe you need new batteries a-hole
Posted on Apr 22, 2008
SOURCE: PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Posted on Nov 21, 2008
SOURCE: hd channels work only some times and some don't come in at all
hi how can I unblock the factory settings on my flat screen TV. If an adult programme is being shown I am blocked out.
Thank You
Posted on Dec 24, 2008
  • 668 Answers
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
I'm trying to connect to antenna. Every time I scan the channels it only scans Channel 1.
The main system control memory IC to this set is faulty. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 01, 2016 | Hitachi Televison & Video
HOW TO CONNECT ANTENNA TO MODEL # LDVD22-10A
You will need an antenna with a standard 'F' connector (Think Cable
wire end) Find the matching screw on 'F' terminal on back of tv & screw/push on (screw on type of connector is better). Then turn on the tv, go to TV input, & do an auto channel scan. It may take awhile. Be patient. After the scan is over, you should have SOME channels. I say that because Digital signals are the only ones available by antenna, & they ARE VERY SENSITIVE TO ANTENNA LOCATION & ORIENTATION. If you get no or few channels,l move the antenna & do auto scan again.
Samuel Morris
Camtek Of NY
Oct 13, 2014 | Televison & Video
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
How do I set up an antenna for tv signal with my 57uwx20b? Do I need a special code to put into the converter box?
U planning to get free air tv?No need for a converter box,ur tv have digital tuner inside.Just plug in ur antena.Go to ur tv menu go to setup pick air scan all ur channels,well get all free air channels.
Feb 12, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Dec 27, 2008 | Hitachi 51F510 51" Rear Projection...
try to enter your setup menu and auto programed the channels that you receive.
Apr 13, 2008 | Hitachi 51F510 51" Rear Projection...
RePost:Hitachi 51F510 W/ No Power HELP
The convergences amps are found either on the neck of the CRTs, or a seperate board directly connected to that area via cabling, depending on version of chassis...accordianman
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Open Questions:
Televison & Video Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
