Question about Amana PTH123B25AJ Heat Pump Air Conditioner
My patc hotel style ac unit compressor turn off after 6 minutes.
I have a PTAC 12000 BTUs style AC Unit that the hot air discharge runs into a box 6 inches away open at both ends. Is this why the compressor keeps turning on and off after 6 minutes.
    Sergeant:
  • 340 Answers
Yes
Posted on Jun 18, 2009
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Dec 08, 2014 | Dryers
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Im buying a ac unit model number is 10aja4801 is this a four ton unit
units are measured in btu's there are 12000 btus per ton. there is a number in the model number that is divisible by 12. the 48 in your model number indicates that it is in fact a 4 ton
Sep 07, 2012 | Heating & Cooling
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a TRANE XR12 central AC UNIT, when i turn my thermostat on i get a click sound and ac unit does not come on. i checked the circuit breaker to make sure it's on.i have not turned this ac on for a...
There is a time delay on the stat to the AC unit, in addition the AC unit likely has one also, so immediate activation as desired isnt likely, however in 10 minutes of asking for AC if its not on still Id check the time delay fuses in the service disconnect at the AC unit, its a small grey box with the power cords running to and from it, there is 2 time delay fuses inside this box.
Jan 12, 2011 | Heating & Cooling
The ac is a window unit its blowing air out strongly but the air coming out is not cold
Make sure the condenser fan is running. That is the one that blows hot air outside. Also see if you can tell if the compressor is running. There is a discharge line and a suction line on the compressor. The suction line should feel cold and the discharge line will be very hot. If the condenser fan and compressor are both running then you may need to get the refrigerant charge checked.
Jun 04, 2010 | Kenmore Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
683 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
