Lenmar Meridian Portable Battery Logo
A
Anonymous Posted on Apr 17, 2014
Using Lenmar Meridian to connect to iTunes
When I use my Lenmar Meridian portable battery with my iPhone5, I cannot get iTunes to recognize the iPhone. I am connecting the mini-USB on the Meridian directly into a USB port on my iMac. Why won't the Meridian allow iTunes to recognize my iPhone?
How do I get my iphone5 off of the connect to itunes screen and delete the update
Download TinyUmbrella and use the "exit from recovery" option. Make sure you are using an Apple certified cord always when syncing or updating your phone.
Disabled iphone5 how to fix without itunes
Hi Michael,
It's actually not possible to fix a disabled iPhone without iTunes. You'd have to connect it directly or in DFU mode and then perform a full reset.
-AB
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
My Computer and iTunes does not recognize my iPod
Look into the bottom of the iPod where the USB connects. Make sure none of the pins are bent and that there is no corrosion visible. Also, are you using the same cable when you connect the different devices?
3answers
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
3answers
3answers
Top Lenmar Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Lenmar Water Sport Expert? Answer questions, earn points and help others
