Question about Bower SFD926 TTL Flash for Nikon
Bower sfd926 makes clicking sounds when turned on
Took about 140 shots with flash, all turned out good. But now flash just clicks when turned on. Does nothing at all now.
Why does it emit a loud whistle when turned on?
I got rid of my Altec Lansing because I got white noise when the unit was turned OFF. They are not a good make. You can try moving any wires or magnetic influence away from them. I now own Bowers and Wilkins MM1 speakers which are amazing.
Bowers Wilkins MM 1
Mar 14, 2016 | Altec Lansing New Original Dell ADA995 5.1...
Bower sfd728
What was the shutter, aperture, and iso set at? How are you triggering the flash? (wireless, wired) Sounds like the images are just getting blown out. If you throw them into a photoeditor, and if the files are in RAW format, does taking the exposure down reveal more details?
May 31, 2013 | Cameras
My bower sfd926 ttl flash shoe is broken can it be fixed
It probably isn't worth it to fix it...buy a new one!
Jan 13, 2013 | Bower SFD926 TTL Flash for Nikon
Over exposure
I have the same problem. I've found using the diffuser or bouncing the flash helps.
Jan 11, 2013 | Bower SFD926 TTL Flash for Nikon
Adf won't feed, just makes loud clicking sounds
Normally ADFs have a top feed roller and a bottom feed which turns in the opposite direction . If the top feed roller is dirty / dusty , the original will not be pulled through , Also if the original is very thick ( > 130 140 gsm )
Dec 20, 2012 | Canon ImageRunner 1600 Copier
Fridge is getting warm & making a funny sound could it be compressor?
It could be the compressor or the start relay. If you hear a click sound, then your relay is good and your compressor is shot. If you do not hear a clicking sound, then your compressor is good and your relay is shot. Also check to make sure that under operation even if the compressor does not work the fan should still be spinning, even if it is warm air. Please rate
Jun 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Car making clicking sound when trying to turn it on.
If it doesn't start but clicks...the battery is shot... have it checked at your dealer or local auto parts store. Auto Parts stores usually do it for free!
Aug 01, 2009 | 1997 Mercury Sable
Rapid flash or continuous shots
Hi richelle
Turn the dial to (SCENE)
Scroll to # 12 (SMILE)
Press (OK)
Center subjects face,
Or the center subject in a group photo.
Say Cheese,
Click,Click,Click You got em
A couple of help full hints here.
#1 You need good lighting, so the face/smile detection works.
#2 Make sure you center the mouth in the on screen [brackets]
#3 Helps if they have teeth :o
You have very good taste in cameras.
Best regards and keep em smiling : ) Paul
May 18, 2008 | Olympus FE-280 Digital Camera
Bower SFD926 TTL Flash for Nikon Logo
Top Bower Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Bower Camera Expert? Answer questions, earn points and help others
