Question about Car Audio & Video
2005 toyota echo cd player will play cd's but not mp3's
The player accepts a MP3 disc ok, display shows that it is loading then Error 1 is displayed
SOURCE: Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Posted on Jun 13, 2008
  • 11 Answers
SOURCE: CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
Posted on May 21, 2009
  • 4 Answers
SOURCE: MP3 convertion
You have to convert mp3 to an audio file first then it will play. (using a computer an a burning program....ie mindows player,nero ect...
Posted on Jun 30, 2009
SOURCE: not accepting cd's
I have the exact same car a 2005 Ford Focus ZX5 with a 6 disc MP3 player, when we first got the car the changer worked fine and would read all discs, after a few weeks it would kick out every disc and say that it was "bad disc", we tried buying just some office depot cleaning disc thinking it would clean the laser. This did nothing, tonight I got quite ambitious and removed the whole deck from the dash. You do this by carefully prying back the surrounding plate all the way around the heating controls and then unbolting the deck from the car. I unhooked the cabels that were running into and pulling it out. I then unscrewed all the small screws to the unit and took a look inside. As it turns out I wasn't able to find the laser eye as the changer had hidden it, so I screwed it back together and put it back in. Turned on the player and put in a disc and it played perfectly. So in the end basically unplugging it and plugging it back in did the trick. You may also have the same luck just unplugging the battery for about a minute and plugging it back rather than taking your dash apart. Hopefully that helps you since it's been 4 months since you posted this issue.
Posted on Jul 09, 2009
97F350diesel
  • 1326 Answers
SOURCE: Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Posted on Aug 07, 2009
Disc will not load into subaru forester cd changer
This also happened to my 2002 WRX. I took the CD player out of the console and found a tiny spring (which I could not find) was not in its location, which would actuate the "play CD" switch inside. After a few hours I decided to reassemble the player and use it as a non-CD unit. The radio and cassette player still work, so I purchased a cassette MP3 player adapter so I can plug in my cell phone and play songlists.
May 09, 2014 | 2005 Subaru Forester
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
The cd player in my radio displays error 1
You are trying to play a disc in the wrong format. (like a mp3 file) or your laser is weak in your player.
Mar 08, 2010 | 2004 Toyota Corolla
Mp3 player display file system error
Hello Cesarsmith,
Please find reset button hole and insert something in it to press and your Mp3 players work fine again.
Thanks for using fixya.
Jun 15, 2009 | Insignia Sport lDM9700-2 Personal CD...
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
MP3 CD not recognized by Sony-Error "No Disc"
the mp3 files have to be recorded in the ISO9660 level 1 or level 2 format, or the Joliet or Romeo in the expansion format.
Please note this is verbatim, straight from my Sony manual.
For details of your recording format you will have to see your converter's help or configuration files.
May 13, 2009 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Jun 12, 2008 | Clarion Car Audio & Video
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
