Question about Garden
I have a Stihl MS 210 C chainsaw that I cannot start. I rented it from a local rental store but it is not closed and I cannot start it. Have set choke and after several pulls switched to regular throttle setting but cannot get any signs of life either way. It ran fine at the rental place just an nour earlier. Do not think that I have flooded it, I do not smell excess gasoline smell. What can I try?
  • 1,305 Answers
Take the spark plug out and dry the plug, pull the motor thru a few times, then reinstall.
Make sure that the on/off switch is in the ON position.
If there is a start position for the throttle with a latch to hold it in place, set it.
Pull thru, if nothing, choke full once and then off again..
K
Posted on Jun 18, 2009
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
How do I change a chain on a Stihl ms 210?
Take off the side cover at the base and loosen the tension screw. Blade should slip off. Make sure when you replace it, you do not tighten it too far.
Sep 20, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Stihl ms 210 manual
Here is website for manual: http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/ms-210-230-250-chain-saw-instruction-manual.pdf
Sep 08, 2014 | Garden
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual:
Spark plug (resistor type): Bosch WSR 6 F
Electrode gap: 0.02 in. (0.5 mm)
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-MS-210-230-250-Instruction-Manual.pdf
Apr 28, 2014 | Standard Oregon Chainsaw Chain For Stihl...
Having trouble shutting off Stihl chainsaw
the kill switch wire might have broke between the coil and the switch
May 19, 2012 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
1,015 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
