Question about Electric Mobility Health & Beauty
Rascal 310 mobility scooter
Battery charger does not work. what is the part number for this charger??
gewiz
  • 1271 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
  • 177 Answers
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Posted on Jul 07, 2010
  • 692 Answers
SOURCE: manual for rascal mobility scooter,
Bub see the following web http://www.rascalscooters.com/index.cfm/mobility/service.manuals
I don't know if they list your model but they have an 800# you can call to get help Hope this helps you
Posted on Sep 10, 2010
SOURCE: I NEED A USER MANUAL FOR A RASCAL 388XL MOBILITY
Send me your email contact details, and bI will send you what I've got.
aidee
Posted on Sep 26, 2010
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
I have a rascal and put new batteries in it and it seems they will not charge up what could be the problem?
Hi Chris,,,, Now lets get the silly question out of the way first, have you tried another charger ?
IS it a built in charger ?
Remember a bad charger == Bad batteries...
the lead that goes from the chagrer socket to the batteries via the controller are most likely adding resistance that the charger does not like ...
Regards
Robi
Aug 31, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
Find vin number on rascal scooter
Depending on with Rascal scooter you have, The 600's number can be under the foot plate which means turning the scooter onto its back supports to have a look. The numbers can be stamped into the metal support for the seat post or even a sticker stuck on the rear frame work of the scooter. But about the batteries the other answer you got is correct.
Feb 07, 2015 | Electric Mobility Rascal Scooter...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
Need a battery charger for rascal 600t
I recommend the 5 amp Charger. Monster Scooter Parts have them.
Apr 09, 2014 | Electric Mobility Power Electric Scooter...
Convert off board battery charger to work on rascal scooter
It has been done before, but you will violate the safety to do that and anything that happens with this scooter will be your fault! You will need a female electrical part for an XLR Plug to make it so the Male end from the charger will plug in. after wiring the Female connector and plugging the charger in the scooter will run while the charger is plugged in. This can cause safety problems.
Apr 03, 2014 | Electric Mobility Health & Beauty
What kind of chargers can i use for rascal 600
I would recommend the correct automatic charger as you don't want to damage your batteries or have a fire/explosion.
Mar 27, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal Scooter charger blew twice is it caused by something else or do I just need a new charger. Someone fixed it and it worked 5 minutes.
it is posible the batteries are not installed with the right poles or there may be a short, but more lightly the charger is dud.
Nov 14, 2013 | Electric Mobility Power Electric Scooter...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Batteries do not charge but charger is working. Rascal 600T todusty@juno.com
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
Jul 02, 2010 | Electric Mobility Mobility Electric Power...
Health & Beauty Logo
22 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
