Question about LG DLG5932W Gas Dryer
Lint light stays on lg dryer dlg4802w - LG DLG5932W Gas Dryer
4 Suggested Answers
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: LG DLG0452W: Light inside the
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Posted on Jan 10, 2011
The display panel on my DLG4802W is not working and dryer will not come on
Check breaker. Find where you are loosing power. Don't mess with too much if you are unsure about how to check for electricity
Oct 27, 2013 | LG Dryers
Newer LG front load gas clothes dryer. power hooked up dryer controls light and operate. gas hooked up and flowing. i hear the igniter light but gas doesnt stay lit. no heat. do i need a special gas dryer...
if you hear the flame light but it doesn't stay on for a long time most likely you have lint blocked up in the dryer or in the vent linepull out the lint screen filter and look down into the duct that the filter slides into,if that's blocked you can try to stick a brush down in there and pull out as much lint as you can and then get a shop vac and set it up to blow and try to blow the rest of the lint out,if this doesn't work you have to pull the front of the dryer off and clean out the duct,also vac and blow out the gas tube and the motor and vac up any lint that's in the cabinet,unplug the dryer,remove the top,then the control panel and then the front panel.put it back together and then go out side and make sure the duct is clear no cage or screen,go back inside,remove the vent line off of the back of dryer,if it's a long run to the outside stick a leaf blower into the vent line and blow it to the outside,put it back together and you should be fine.this should be done once a year with a gas dryer so you don't have any problems with parts or how it's running and most important you won't have a fire.if you need anymore help let me know.
Oct 07, 2013 | LG DLG3788W Gas Dryer
LG Dryer not heating at all. DLG4802W gas dryer. Already replaced two thermostats Thermostat 6931EL3003C and Thermostat Assembly 6931EL3004B and still not heating. Only 18 months old.
Check your igniter, if that does not get hot enough it will not open the gas valve. If it does not glow at all check for voltage if voltage is present 120vdc replace igniter.
Jul 31, 2013 | Dryers
The dryer is taking a lot longer to dry now than before. I'm sure it's not lint, insufficient gas supply or the vent needing cleaned. The cooling light is staying on solid and the drying light...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 06, 2011 | LG DLG2524 Gas Dryer
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
Jan 10, 2011 | LG DLG0452W Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
LG dryer check filter light
Have you checked the lint trap? If not this is what it is talking about. If you have then you should check your dryer vent line. Your lint trap should be on the inside of the dryer. If you need more help let me know. Also if you unplug the unit after checking what I said and the light still is one. Unplug it for 1 minute then plug back in this should reset everything
Feb 09, 2009 | LG DLE5977 Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLG5932W Gas Dryer Logo
41 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
