Question about Kenwood TS-440 ATU
Power cable I need a power cable for kenwood ts440sat
    Master:
  • 623 Answers
It's the standard Kenwood/Yaesu power cable. You should be able to order one from HRO (www.hamradio.com).
Posted on Jan 22, 2015
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
What is the wirer color diagram 1999 toyota avalon car stereo radio wiring diagram radioconstant12v+wire??
Hi Slick, From my experience working on Toyota motor vehicles, they don't use colour coding. You'll need to identify the cables with a voltmeter and an used AA or AAA battery (like those from the TV remote). First find the constant power (which keeps the memory function of the set powered. Then by a process of elimination turn on the ignition and check each of the other cables until you find the ignition switched power. Check to make sure it' switched by turning the ignition on and off. To identify the speaker cables there should be a number of white cables with black tracer lines. Take any pair (removing a little insulation from the end to leave the metal cable open) and hold one cable onto the negative end of the battery and swipe the other cable end over the positive. As you do that the cable speaker will make a popping sound, where by you can identify which speaker is attached to what set of cables. Regards John
Oct 24, 2012 | Toyota Cars & Trucks
Does the kenwood ck414 range come with a power cable supplied?
I doubt it. Use the existing power cable if it is the correct size. Otherwise a trip to B+Q may be needed.
Hope that helps.
Jan 15, 2011 | Microwave Ovens
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Fuse blew on on cable coming from batter, replaced fuse now my kenwood excelon ddx7015 and amp xxv-02a wont power up , but when i test the fuses they have power
What size fuse are you using? You need a 30-
amp at least and #8 to #10 wire I would go
with the # 8 maybe lower, if it blows a fuwse
now you have a shorted output in your amp.
May This Will Help.
Sep 08, 2009 | Kenwood XXV-02A 4 Channel 25th Anniversary...
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
Kenwood KAC-X1R and one 12" Kenwood KFC-XW1222D at 1 ohm blow out.Why is that happening?
You may have a high resistance in your positive or negative power supply. with your amp you need to use at least a 2 gauge power cable. Is your fuse blowing? if so then a short circuit to ground may be causing that.
Good luck
Aug 01, 2008 | Kenwood Car Audio & Video
Ipod Video and power up screen
if its the new gen ipod kenwood needs to come out with a new cable. Old cable does not work on video
Sep 06, 2007 | Kenwood DNX7100 Car Video Player
Kenwood TS-440 ATU Logo
83 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
