Question about Kodak Office Equipment & Supplies
Kodak 750h won't reverse - Kodak Office Equipment & Supplies
    President:
  • Kodak Master
  • 412 Answers
If the projector cycles in FORWARD and holds SELECT when the SELECT button is pushed and held, then the projector simply needs a cycle solenoid adjustment. This can be accomplished by following the adjustment procedure in the Kodak Service Manual posted at: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
Good Luck !! Jim
Posted on Dec 17, 2014
4 Suggested Answers
  • 412 Answers
SOURCE: model 750H overheated and guide says
That is correct. There are 2 thermal fuses: 1 near the lamp, 1 on the power motor. This repair should be made by a factory-trained tech.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: Kodak 750H and 760H neither will advance carolsel without manual
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
  • 412 Answers
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
Posted on Nov 21, 2010
Want to buy a kodak 750H power cord
Check for the power cord at: www.micro-tools.com
They bought the entire Kodak service parts inventory about 10 years ago.
Good Luck!! Jim
Jul 20, 2015 | Kodak Office Equipment & Supplies
My Kodak Carousel 750H slide projector will not forward next slide or reverse
Your projector problem sounds like a broken cycle solenoid LINK. The LINK will be available from: www.micro-tools.com
They should have installation instructions, as well. See the attached picture for more details. Good Luck!! Jim
Dec 09, 2013 | Kodak Office Equipment & Supplies
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
Kodak 750h Projector - The Carousel won't advance when the level is pushed?
If the projector fails to change slides in forward or reverse, then chances are that your projector has a broken cycle solenoid link. The link connects the slide change (cycle) solenoid to the slide change mechanism. Over time the link (made of plastic) gets brittle and cracks. The good news is parts are still available ( www.micro-tools.com) The bad news is this is a difficult repair and usually requires a service manual and a factory-trained repair dealer. Good Luck!!
Jan 20, 2011 | Kodak Office Equipment & Supplies
I have a 750H Kodak slide projector. Where do I find a bulb for it?
The KODAK Carousel 750H uses a 300 watt, 120volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 19, 2010 | Kodak Office Equipment & Supplies
Focus Lense Will Not move using the remote or the dial - What can I do? Kodak Carosel model 750H
The KODAK Carousel 750H was manufactured from roughly 1971 to 1981.
If you can push the focus knob toward the outside of the projector and manually remove the lens, then the problem is the gear on the focus shaft (the shaft the focus knob turns). The gear has either cracked and fallen off or is cracked and slipping on the shaft. Either way, the focus shaft needs to be replaced by a factory-trained repair technician.
Jul 08, 2010 | Kodak Carousel 4400 Slide Projector
May 12, 2010 | Office Equipment & Supplies
Mar 20, 2010 | Kodak Office Equipment & Supplies
My kodak carousel slide projector model 750h will not operate in the forward position. What could be the problem and how much to repair?
If reverse and select modes work correctly, it could require a slight adjustment of the cycle solenoid or (worst case) it may be a broken spring on the slide tray advance lever. To pinpoint the cause of your problem, take your projector to a factory-trained repair dealer.
Mar 06, 2010 | Kodak Office Equipment & Supplies
Model 750H overheated and guide says
Sep 17, 2009 | Office Equipment & Supplies
97 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
