Question about Dryers
I have the same problem!
When I push the start button, it makes a humming sound and it smells like burning wires for a minute.
  • 82 Answers
Don't do that anymore! If you're lucky, there is just something caught in the vent fan, if not you will probably need a new motor.
Posted on Jun 18, 2009
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
KENMORE DRYER WILL NOT START
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
Dryer drum ot turning but start button hums like it supposed to
sounds like your motor might be stuck and the motor is sitting there trying to run until it trips out on the overload
Jan 22, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
Marvin
Marvin
