Question about Hotpoint Dishwashers
Hotpoint HDA3500N10WW doesn't drain
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Lcode 1 flashes and drain pump doesn't stop
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Jan 01, 2013 | Hotpoint-Ariston LFT 321HX Dishwasher
Hotpoint Aquarius wf541 fabric conditioner compartment fills with water and doesn't drain out
There is a syphon tube with a cover dome like a thimble. Lift it off, clean it and clear the syphon tube. Refit the cover.
Apr 25, 2012 | Hotpoint Washing Machines
My hotpoint frost free, fridge compartment keeps collecting water at the bottom of the fridge. I've checked drain hole is clear of any bits. The temperature strip in fridge is constantly black and ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Why does the machine not empty the water, machine is a hotpoint super silent load wt90 1600 spin
When giving model and make information, you should take it off the id tag because that is how all our repair systems are set up.
Since I can not call up you model, I will have to give you a generic answer.
You first need to check and see if the machine will drain in any of the other cycles (permanent press, regular, delicate). If it doesn't then either your drain pump has stopped working and needs replaced or something like hose or a sock has clogged the drain pump intake. You should also check to make sure that nothing has block the drain hose.
Jul 20, 2011 | Hotpoint Washing Machines
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
Jun 17, 2011 | Hotpoint Washing Machines
Water not draining from dishwasher modle number hotpoint DWF32P/29 how do i get to the hose to see if its blocked
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | Dishwashers
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Dishwashers Logo
32 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
