Question about Luminara Flameless Candle Remote Control - -
Cant get battery drawer open
How am I to get the battery drawer open? I try and try to no avail.
How do i unlock my system
under the Dvd drawer tray towards the right hand side where you have the open close button just next to it you will see a small pin hole. you can insert a safety pin in the pin hole and push it so that you can open the DVD drawer. Good Luck
Feb 07, 2012 | Gigabyte Intel G31 775 DDR2 )
Sony camcorder drawer has jammed open
problem solved by friend who found a by-pass socket for charger on camera which charged battery enough to close tape drawer. Thank you
Jan 07, 2010 | Sony Video Cameras
Have f1 fault cant get bottom draw out to check for moister build up
The reason that you are getting F1 fault might be the dishwasher drawer is flooding. The drawer not opening is perhaps due to either the keylock being activated or the controller has gone into some unkown state.
Try turning the mains water inlet water tap off and also switch off the power. Turn everthing back on and then check if you can open the drawer. If you have water inside the drawer you may need to empty it manually with a small container. If it floods again, then the solenoid that turns of the power or the water level sensor might be faulty.
Nov 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Freezer drawer on sub zero stuck
chances are it is frozen stuck and also needs lubrication. Do this. Unplug it for an hour and try the drawer. If it doesnt open wait another half hour and try it again. When it does open, dry the rails thoroughly with a towel and then a hair blow dryer. Finally spray the rails with a lubricating spray like WD40 or better yet some white lithium lubricating grease, both products readily available at any hardware store, home depot, etc.
Oct 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
Powder drawer wont open
Grasp the drawer firmly, and pull out until it reaches its stop, then press the plastic lever down in the middle of the drawer at the rear, and pull the drawer out.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Ps3 will not load any games
hi...
Your drive is either really dusty inside or has failed.
You can dust it out by getting the drawer to open and unplug the power ( keeps the drawer open)
Blow some compressed CO2(dust-off) into the drive area thru the drawer.
Try your game again. If not, have a tech replace the DVD drive.
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Drawer will not open
1-800-4my-xbox you will need your xbox repaired by microsoft no worries its all free even the shipping
Nov 24, 2008 | Microsoft Xbox 360 Console
Soap dispenser drawer jammed
Dear SK8RMOM,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | LG WM-2277HW Front Load Washer
Date/Time Reset Every Time I Turn the Camera On
Open up the battery door of your camera. There's a little slide drawer labeled CR1220. Use your fingernail or small screwdriver to pry and slide it open. This little button battery runs your camera's clock. Remove and reinstall it to see if that fixes it. If not, time to buy another battery. The CR1220 battery is very common, inexpensive ($2 to 3), and available at most stores (try your local drugstore). Take the old battery with you to the store to make sure you buy the right one.
Jul 31, 2008 | Canon PowerShot A540 Digital Camera
DVD drawer will not open
I had luck with disconnecting the power cord from the back of the unit.
Jan 29, 2008 | Bose (321GS) System
Luminara Flameless Candle Remote Control - - Logo
290 people viewed this question
Top Luminara Home Experts
Donni Steen
Tom Chichester
Are you a Luminara Home Expert? Answer questions, earn points and help others
