Computers & Internet Logo
A
Anonymous Posted on Apr 17, 2014
How do you enter initial balance forward?
We are merging two programs into 1 bringing balance forward from system new system will intergrate all I have in are the client names
QuickBooks Support
Level 1:
Habit-Forming:
New Friend:
  • Contributor 90 Answers
  • Posted on Aug 26, 2014
QuickBooks Support
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
90
Questions
0
Helped
30423
Points
92
1helpful
Only rings 3 times then transfers to another ext.
Mitel call forwarding is a double-edged sword. It can be controlled by the end user via user-programmed forwarding and it can also be controlled by the system programmer via system call rerouting. User programmed forwarding OVERRIDES system programmed 1st alternate, but does not override the 2nd alternate reroute destination (if 1 is programmed). Try un-forwarding the phone - if still no joy then contact the system support person. Hope this helps. (User-programming commands are initially defined by the system support people when the system is initially installed, so I can't tell you how to do it... you'll need to know what the key commands are (or unforward using the Superkey function if provided).
Merge customers in quickbooks
In order to merge the customers, they must NOT have an open balance for accounts receivable.
Edit the one that is correct and copy the customer/company name.
Edit the one that is incorrect, and replace the customer/company name with the correct one.
As you save it the program will ask if you would like to merge them.'
As always, make a backup before merging so you can easily recover if you merge the wrong customers.
When trying to take picture of my children it is very blurry. Yes they are somewhat moving but it didn't use to be as bad as what it is now. Should I try another setting? Thanks
Check if the white balance setting in the camera menu is set to Auto White Balance (AWB) . Ordinarily, the auto white balance function of the camera can resolve issues with color accuracy, but sometimes certain lighting conditions can still cause discoloration. For example, the entire image may appear blue under cloudy conditions and white subjects may have a reddish tint under incandescent bulbs. If the auto white balance does not resolve the issue, try a different white balance setting, depending on the condition - Daylight , Cloudy , Fluorescent , etc.
If the issue still persists after changing the settings, please initialize the Camera and that should resolve the issue.
To Initialize the Camera,
Press MENU to display the menu of the Camera.
After pressing the FORWARD ARROW key on the Control buttons, go to SETUP and then press the FORWARD ARROW key again.
Scroll to the SETUP 1 submenu using the Arrow keys. Press the ENTER key ( the key at the center of the arrow keys ) once you reach SETUP1.
Then scroll to INITIAZE setting.
Then select the INITIALIZE option using the ENTER key and then select the OK option.
Then press the ENTER key to select the OK option.
After initializing, the Clock Set will be displayed, set the Clock and capture an image and then the images should appear perfect.
If the issue still persists, then the Camera requires to be physically examined to determine the exact issue.
Thank You!
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
6helpful
2answers
Changing time
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.-
Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
7helpful
3answers
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
I want circularlinklist program in c++
This C++ program is to perform the following operations
on a circular linked list
1)insertion
2)forward traversal
3)reverse traversal
4)search
->node structure :
a node contains
1) integer data
2) pointer to next node
-> This program works in microsoft VC++ environment
in windows xp
-> This program uses the following header files
1)iostream.h
#include<iostream.h>
class cll
private:
int data;
cll *next;
public:
cll* insert_one(int,cll*);
cll* delete_one(int,cll*);
void ftraverse(cll*);
void rtraverse(cll*);
void search(int,cll*);
void function();
cll*hd;
void cll::function()
cout<<”******************************************\n”;
cout<<”program to implement a circular linked list \n”;
cll * head;
head=NULL;
cout<<”\n\nMENU :\n”;
cout<<”1)insertion\n”
<<”2forward traversal\n”
<<”3)reverse traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cout<<”Enter your option :”;
int opt;
cin>>opt;
int d;
while(opt!=5)
switch(opt)
case 1:
cout<<”Enter data to the node :”;
cin>>d;
head=insert_one(d,head);
cout<<”inserted\n”;
break;
case 2:
cout<<”The forward traversal is :\n”;
ftraverse(head);
break;
case 3:
cout<<”The reverse traversal is :\n”;
hd=head;
rtraverse(head);
cout<<”NULL\n”;
break;
case 4:
cout<<”Enter the element to be searched :”;
int d;
cin>>d;
search(d,head);
break;
case 5:
break;
default:
cout<<”invalid option”;
break;
<<”2)forward traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cin>>opt;
cll* cll::insert_one(int d,cll* c)
cll*NEW;
NEW=new cll;
NEW->data=d;
NEW->next=NULL;
if(c==NULL)
c=NEW;
c->next=c;
else
cll*c1=c;
while(c1->next!=c)
c1=c1->next;
c1->next=NEW;
NEW->next=c;
return c;
void cll::ftraverse(cll* c)
if(c==NULL)
cout<<”\nlist empty\n”;
return;
else
cll *c1=c;
cout<<c1->data<<”->”;
c1=c1->next;
while(c1!=c)
c1=c1->next;
cout<<”NULL\n”;
void cll::rtraverse(cll* c)
if(c->next==hd)
cout<<c->data<<”->”;
return;
else
rtraverse(c->next);
void cll::search(int d,cll* c)
cll*c1=c;
if(c==NULL)
return;
else
if(c->data == d)
cout<<”found\n”;
return ;
while(c->next !=c1)
if(c->data==d)
cout<<”found\n”;
return ;
c=c->next;
if(c->data ==d)
cout<<”found\n”;
return ;
cout<<” search unsuccess ful \n”;
void main()
cll list;
list.function();
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
