Question about General Electric Monogram® ZGU385NSMSS (Gas) Stainless Steel Cooktop
Just replaced the transformer. Stove lights and operates perfect until I put the SS top back on. Then it won't ignite.
2 Suggested Answers
  • 10865 Answers
SOURCE: Glass stove top with enclosed
Hello mfry.... It is true that these glass tops do get more brittle as time goes on and there is the chance that it could break. That said, if the top breaks, you can generally buy a replacement top. I would begin by removing the glass. If it doesn't break on the way out it probably won't break. Once the top is off, then get the replacement ignitor.
If you want to see if these parts are available get the model number and go to the searspartsdirect.com website. Enter your model number and you should get the parts diagrams along with the prices. Joe
Thanks for choosing Fixya!
Posted on Feb 04, 2011
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Constant buzzing noise, must be transformer but stove works perfect. is this normal
Look to see if coiled gas line is vibrating against back of stove. (Or try pulling stove forward a bit).
Otherwise, you are probably correct about a transformer. It can be ''defective'' and still work.
May 18, 2015 | GE Profile JGP636 Gas Cooktop
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
MAYTAG GAS STOVE
One or more of the control switches has shorted out. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when you put them back on. Maytag /Jenn air have had recalls on some models for this problem as it can start a fire under some conditions. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!! You can still light it with a match. Check Maytags Web site for information on this . Some switches can be seperated from the gas valve and replaced sererately. This may be worth fixing. Remove the wires from all switches and re connect them one at a time until you find out which switch/s are bad. If this was left clicking for too long you might have burned out the spark module. If the switches are part of the gas valve, and more than one is bad it may not make sense to fix the cooktop. Remember you can always just disconnect the switch that is bad , use the rest and light the broken burner with a long reach lighter.
Jul 07, 2008 | Cooktops
General Electric Monogram® ZGU385NSMSS (Gas) Stainless Steel Cooktop Logo
89 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
