Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV will not turn on
We have a Westinghouse W2613 HDTV and we were watching it and it just went off. It will not turn back on with the remote or the tv button. We unplugged it and waited and still doesn't work. Can't find anything in the manaul about this problem. When we try to turn it on the red light on front of the tv just flashes three times and nothing helps. Any ideas?
Thanks.
  • 6,784 Answers
HI, this is a failed inverter board. this will need to be replaced in order to restore proper functions.
This failed board is responsible for distributing the power through out the set. it has failed.
Posted on Jun 18, 2009
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Westinghouse W2613 to Macbook - "Mode not supported"
You need an HDMI driver... also sometimes a special HDMI cable is used for Apples too, I believe. Also a lot of sets must start with a resolution of 800x600 32bit. Also research if HDMI is actually possible from your video card too. Some HDMI doesn't send the audio via the cable either you must use AV audio out.
Feb 02, 2010 | Televison & Video
Broken LCD-Panel for model Westinghouse W2613 Can't find replacement part anywhere. Is it worth fixing?
i know some one had a broken lcd on a sharp aquos and it would have cost more to fix than to buy new
Dec 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse TV - Issues
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/..
Mar 10, 2017 | Westinghouse LTV-19W3 19 in. LCD...
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
273 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
