Question about Emerson MW8102SS 1100 Watts Microwave Oven
Microwave plate won't stop spinning - Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Bosch hmt9666 microwave plate stopped spinning while being used? Can't seem to find replacement part. Help needed
Try www.bosch.com contact customer support and the technical department, also check www.ebay.com type make and model of the microwave oven and scroll through the list.
Jun 15, 2012 | Bosch Microwave Ovens
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
The plate of my microwave own doesn't turn
Turntable motor must be replaced.
May 28, 2010 | Microwave Ovens
Turntable has stopped revolving... will start to spin as soon as START button hit - goes about half an inch and then completely stops.
One suggestion i would make is that in the microwave there is the turntable, lift the plate off ,then below it you will see a circular object with wheels on.I think you may have this the wrong way up, so turn it over put the plate back on top and should work.
its the circular piece on runners that is the problem
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave plate has stopped spinning, am I safe to use it still?
yes its safe but wont cook evenly sometimes the gears go bad under the pan and need to be fixed
Sep 01, 2009 | Microwave Ovens
GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
