Question about Maytag Bravos MTW6600T Top Load Washer
Fail. code b5 in machine MAYTAG
CYCLE INCOMPLET
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
My Maytag Neptune TL will not switch cycles, when I started the wash cycle it said 57 minuntes came back 1/2 hour later and it still said 57 minutes tried unpluging it to see if it might clear any erriors...
What happens if you do a Spin Only cycle with that wash load?
Does it fail to go thru the 12 min Spin Only Cycle?
Any error code to the console?
Do you want to troubleshoot?
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will spin empty but after half load ...stops
Any error codes with the fail to spin? Is the wash Tub banging around in Spin Cycle of the Wash Cycle?
Oct 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AWW Washer was working fine then failed to enter spin mode and would not drain after a wash cycle. Repair tech came and said both control board and clutch was bad. What are the odds...
What error codes if any for failing in Spin Cycle?
If the Clutch One-Way Roller bearings are Slipping in spin cycle you will get tumbler movement as the wash basket begins to spin up.
If the TSD is working as designed you will get unbalance errors such as dC or uC and the machine will shut down. This tells me the Control Board is responding correctly to the Tub Displacement Sensor (TDS) signaling. Is that the failure scenario?
See this post Clutch Fix for Fail to spin issues related to a Clutch malfunction. This is a very common problem for the FAV6800A and FAV9800A machines
If you can provide additional info on you issue that would help me. Does the tub bang around as you enter spin cycle then fail with unbalance error codes?
Most service techs do not have much hands on experience with the machine. If we can get closer to the fail point and you can DIY the fix you will save big dollars.
I will guess you quote to repair is in $350 to $500 range maybe more
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer wont drain and finish a cycle
Is the wash tub banging aroun in Spin Cycle and failing with a unbalance code of dC or uC?
What is the model number?
May 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Oct 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl displays LL and stops during the rinse cycle
Sorry chukenne,
Having not experienced this issue on my FAV6800AWW I missed this error code in the manual is that your machine type? Error code “LL” is documented in the troubleshooting part of the SM as Large Load detected. Does this happen with all wash load sizes? I would go into Service Mode and step thru and document Diag codes form page 17 of the SM and see if you find any recorded error conditions. I would be curious to see if error code block 16 indicates a fail condition. I'm thinking of a possible high motor torque condition detected that may have triggered the LL code just a WAG at this time. You may want to clear all error codes and start collecting from your next wash cycle but I would make a list of all codes before you clear them for reference of fail events of past wash cycles. I’m going to assume the LL code happened during a spin cycle. What caused you to drop the clutch out and re-lube/ Were you taking dc/UC errors in spin cycle? Rich
May 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
