Question about Music
Kurzweil pc2 waiting for scanner freeze - Music
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
I am looking for a manual for the Kurzweil Reader Model 7315-60.
Your best bet would be to contact Kurzweil Customer Service directly.Here isa link to their Support page-
Kurzweil Education
Feb 23, 2015 | Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
PC3 freeze
Probably the battery is low insite it takes ling because it tries to juice the last life from the batterie will get worse until it stops replace it and go
Oct 21, 2014 | Kurzweil PC3K8 88 Note Performance...
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
I NEED KURZWEIL PC2X MANYAL
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/PC2/DOCS/PC2V3MAN.ZIP
May 06, 2012 | Music
My keyboard is being uncooperative. It produces no sound, and displays the following message: “Welcome to the PC-88 . . . Waiting for scanner . . . Scanner is dead! V1.02” Any suggestions?
The scanner is LIKELY the scanner that scans the keyboard matrix. The scanner sends out a strobe to a particular portion of the keys and reads that portion then moves on to the next. The keys are in a big matrix with disconnect diodes to avoid reading crossing in the matrix when multiple keys are presssed at once. Each keky has two contacts whcih allow them to measure how fast a key is pressed because one contact closes before the other.
The "scanner" MIGHT be on a seperate board that has cables to the actual keys area AND a cable to the main processor. OR the scanner could actually be included on the circuit board with the key switches. I would open the unit and look for a cable that has come loose between the scanner circuit board and the main board. Beyond that this will NOT be a DIY repair.
Jan 21, 2011 | Kurzweil SP2XS Keyboard Home
I have a Kurzweil Mark-Pro TWOi. It takes several minutes to turn on, and keeps resetting and clicking while booting up. My guess is a bad capacitor somewhere. I looked at the power board, and it looks...
I don't know what you "tested" the power supply board with, but I would use an oscilloscope to look at the outputs to see if any of the regulators are drooping. Clicking is a broad term... if it is a relay, it PROBABLY is for speaker protection and senses balance of the power amps.
With a two minute delay, this is PROBABLY a thermal issue... Use freeze mist/circuit cooler to find suspicious parts.
Jan 01, 2011 | Kurzweil SP4-7 76 Note Digital Stage...
Music Logo
98 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
