Question about 18 HP V-TWIN GX610 V-Twin OHV Horizontal Shaft
Engine will go dead when you idle it down slow enough to put it in gear
Clutch won't disengage with out going dead
  • 5 Answers
If the car engine has been previously running correctly then have a good look at the air inlet pipes for splits/cracks. This will allow extra air to be sucked into the engine and so weaken the fuel mixture, cut out at idle speed. Replace any split pipes
Posted on Feb 06, 2015
  • 26 Answers
Lost likely your do not have carburator(s)
Fuel Injection in most model cars since 1990's.
My past experiences tell me you have a problem with TPS Throttle Position Switch. I can remember Chrysler products had similar problems. Driving along Highway speeds get off highway and engine does not Idle. Need to have diagnostic tests run checking for Fault Codes. Doubt there are any adjustments you can make.
Posted on Jan 26, 2015
  • George Dubbs Feb 06, 2015
    arent we discussing lawn mower engines here..18 hp vtwin
    Sergeant:
  • 406 Answers
Not sure what you asking..but by what you are saying the carb idle speed control needs adjusted..there should be two adjustment screws on the carb..one in the middle where it hooks to the motor it is the mixture screw do not adujust..the other is located where the throttle linkage hooks to the carb..adjust that one while the engine is running and out of gear..to the right adds speed the left backs it off...adjust to an idle speed that will allow you to operate the clutch..and put in gear..just make sure it isn't one of the safety switches that is not letting you put it in gear..good luck.
Posted on Oct 03, 2014
1994 Polaris 300 4x4 want shift into high range just grinds
Bad linkage between shift lever and the transmission.
Apr 07, 2015 | ATVs
The engine went dead when I slow down to turn on neutral gear. what is the possible cause?
Neutral gear? Standard transmission or Automatic? If automatic
car may be smart enough to shut down. If Standard transmission
you may have a clutch safety start switch wire loose or bad switch.
Feb 27, 2015 | Cars & Trucks
Revs high when i change gear
Is it possible the clutch pedal is interfering with the throttle? Start the engine in neutral and allow it to idle. Press only the clutch pedal down and see if this increase the engine speed. If it does speed up the engine and slows back down when you release the clutch then somehow this operation is where your fault lies. If it doesn't alter the idle speed, then rev your engine and release the throttle to see if it returns to idle immediately. If it is slow to return to idle then your throttle cable could be sticking. This means when you change gear lifting off the throttle has little effect and depressing the clutch to change gear causes the engine to race as the throttle is still partially open.
Aug 23, 2014 | 2005 Ford Fiesta 1.3
1998 jaguar jx8 isn't going into first gear easily...have to rev it to go in, I have been using gears the original owner didn't...mountain driving and all. HELP
it look like the transmission input shaft still turning while clutch pedal is press. the clutch does not disengage enough. now engine off try to put in first gear then press clutch pedal start engine
Aug 23, 2013 | Transmission & Drivetrain for Jaguar...
Ford ranger manual transmission
try bleeding the slave cylinder sounds like the clutch is not disengaging enough to slow the transmission down enough to allow it it to fall into gear
Aug 02, 2013 | Cars & Trucks
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
Manual transmission will not shift with engine running but will with engine off
The reason is that the gears are turn with the engine running, like the clutch is not disengaged. So that is what you need to look at. the clutch or clutch pedal linkage/ hydraulic system. One of these is not letting the transmission slow down enough to engage a gear.
Jun 28, 2011 | 1993 Toyota Celica
My 2003 Ford Focus Zetec engine, I think either the clutch is going out or maybe just needs fluid. It doesn't want to really go anymore, slow to get up to speed. How and where would I check the fluid on...
If you were low on clutch fluid the clutch would not disengage, it would not cause the car to be slow, but it would be difficult or impossible for you to change gears. If you feel the clutch slipping while driving, either the clutch disk and/or pressure plate are worn, or possibly have oil in then from a leaking engine or transmission seal.
Mar 12, 2011 | 2003 Ford Focus
I have a rav4 that won?t go into gear once the engine is started. If the engine is off it will go into gear. So every time I have to stop I must turn off my car put it in first and then start it again....
Change the gear oil. If the gear oil is leaking get it fixed as soon as possible. If all the oil has leaked then it may have severely damaged the gear box.
Aug 17, 2009 | 1998 Toyota RAV4
18 HP V-TWIN GX610 V-Twin OHV Horizontal Shaft Logo
108 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
