Question about Honda Engine Gc160 Gc190 Gcv135 Gcv160 Recoil Starter
Silver looking oil - Honda Engine Gc160 Gc190 Gcv135 Gcv160 Recoil Starter
WHERE IS THE PLUG TO DRAIN OIL FROM A CRAFTSMAN 550 SILVER EDITION LAWN MOWER?
Almost all drain plugs are under the deck. Some are a 4 sided nut sticking out and some are an inner plug (looks like an allen shape plug)
Oct 14, 2014 | Garden
Have 67 silver shadow stored for 7 years what should be done prior to attempting staring besides clean oil clean fuel
Put oil in the carbs. SU carbs correct? Those black things on the top of the carb towers unscrew. You add lightweight oil (Volvo recommends "sewing machine" oil, motor oil will do. This creates a slightly richer mixture when starting out, thus smoother low end acceleration. Invention of Sir Henry Royce himself.
Jul 09, 2014 | 1967 Rolls Royce Silver
Oil leak
it sounds like an auxcillary drive which isnt used on that model engine ,undo and replace the gasket
Apr 02, 2014 | 1990 Chevrolet Lumina
Whining silver box on top of engine.
Go to the dealer and ask a part person to look at it.
Jan 17, 2014 | 2000 Mercury Cougar
Where is the engine block drain plug of 99 sonata 2.4?
Assuming you are looking for the oil drain plug, it is on the back side of the oil pan facing the rear of the vehicle. The oil pan is usually black in color and the oil plug is generally silver in color and about 17mm in size.
Oct 17, 2012 | 1999 Hyundai Sonata
Where is the oil and fuel filter situated on my volvo xc 90 D5 please
The oil filter is usually on the rear bottom of the motor and the fuel filter is inline on the frame rail its a silver/black canister looks like a can of veggies.
Feb 28, 2010 | Volvo XC90 Cars & Trucks
Gear oil silver wear would water be coming in? Rm250 1996 oil had extra 250 mls drain out. Am stripping bike down now where would the problem be in the top of head? Not sure what to look out for
To have silver oil coming out might indicate a problem worth looking for.Silver is usually aluminium.Maybe a spun bearing or bush?If the oil was milky silver, water seal and possibly a g/box prob.Hope this is a good starting guide for you
Oct 06, 2009 | Suzuki RM 250 Motorcycles
Where is the oil filter located in a 2006 Cadillac CTS (2.8L)?
Open hood and stand at driverside fender. Look at oil cap and then 6 inches to rear of cap to see a silver cap with 24mm nut slightly below plastic next to engine. Unscrew cannister cap and lift out.
Aug 13, 2009 | 2004 Cadillac CTS
Honda Engine Gc160 Gc190 Gcv135 Gcv160 Recoil Starter Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
